Posts: 1,085 |
I made a upgraded wiring harness for my low beams.It runs the headlights right from the battery through a relay,and the bulbs are individualy grounded to the chassis.I saw these for $50 at autozone,but made my own for only a few dollars and some parts I had.The result is absolutly amazing,Im willing to bet the lights are twice the brightness they were before.I hooked one side up at a time to compare with them shinning against a wall,and the upgraded side is definently alot brighter.
If you want ot do your own I read up on itHere and Here .I always thought these things were a gimmick,but I am amazed at the light output now.
Just thought I would share.
A little quote from one of the sites,I did measure the same points and got the same basicly the same results:
In many cases, the thin factory wires are inadequate even for the stock headlamp equipment. Headlamp bulb light output is severely compromised with decreased voltage. For example, normal engine-running voltage in a "12-volt" automotive electrical system is around 13.5 volts. At this voltage, halogen headlamp bulbs achieve 100 percent of their design luminous output. When operating voltage drops to 95 percent (12.825v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (12.15v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.475v), bulb output is a paltry 53 percent of normal! [Source: Hella KG Hueck AG, Germany]. It is much more common than you might think for factory headlamp wiring/switch setups to produce this kind of voltage drop, especially once they're no longer brand new and the connections have accumulated some corrosion and dirt
I AM WE TODD IT
I AM SOFA KING WE TODD IT
Posts: 1,939 |
Please tell me you at least put fuses on those power lines!
2000 Silver Frost SVT
# 1637/2150
D.O.B. 01/14/2000
Posts: 837 |
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 1,044 |
Nice find. It sounds like the wires for the lighting circuit were probably undersized as a cost saving without enough regard for the impact on the lights. The power loss for a given size of wire increases as the square of current.
P (watts) = I**2 x R (Amps squared times Resistance in ohms)
A slightly smaller wire will have a bit more resistance but will result in a much bigger power loss at higher currents. Now think what happens when the wire gets hot and the resistance increases even more....
Posts: 1,085 |
Originally posted by t-red2000se: Please tell me you at least put fuses on those power lines!
Yes I did!Wouldnt it be dumb not to!
I AM WE TODD IT
Posts: 1,085 |
Originally posted by Bridge: Do you have any pics?
How do you want them?Once side stock the other upgraded?I can get some tomarrow night.
I AM WE TODD IT
Posts: 857 |
Sounds like a good idea. Useful if you ever think about running HIDs also. I've seen a wiring harness that eliminates the relay and fuses, and uses a FET instead. I'm not familiar with this component, anyone care to indulge in some theory?
Edit: like this: http://www.autolamps-online.com/gasdischarge/Philips%20FETharness.htm
Posts: 19 |
Hmmm...wouldn't the reason they're brighter be because you now running them from a battery being "charged" at approximately 14.7v ?? No magic there. Might burn out the bulbs a bit prematurely. ...Ed
2002 True Blue Mustang
3.8 Ltr. V6, MTX
Posts: 1,085 |
Wow your a genuis! No one said it was magic.Last I checked my battery wasnt putting out 14.7 volts,Genius.Ponder that one.....Genuis!
I AM WE TODD IT
Posts: 99 |
Excellent information, leave it to the Germans to take the time to take those measurements.
I think the ultimate test would be to have someone rev the motor to 3K and stick a voltmeter on the plug. Can anyone see that not giving an accurate figure?
Timothy Grimes
98 SVT #2132
82 320i -Now armed with a hairdryer-
