#48068 11/19/01 07:17 AM
my 95 mystique (zetec, mtx, 95,500 miles) has been running roughly at idle and when cold, so i have been trying to take some steps to change this. i changed the fuel filter, which didn't help the problem. i tried to change the plugs today and i could not get them to turn at all. has anyone else had this problem? the best suggestion i have heard so far is spray some penetrating oil around each plug, give it a week, and pray that it works, or else you'll be trying to rethread an aluminum head, which does not sound like a whole lot of fun. i think the original plugs are still in there.
1995 Mercury Mystique GS
2.0L Zetec, MTX
10% dents all around
its not my fault its teal!!! it was cheap!
#48069 11/19/01 10:26 AM
The "best suggestion" mentioned in your post seems the way to go. Just make sure that the engine is cold when you attempt removal.
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
#48070 11/19/01 01:41 PM
Definately don't force the issue. If in a week, you can still not get them out, take it to a professional with the STRICT instruction not to force them loose. Sounds like the last time the plugs were changed, there was no anti-seize on the threads.
Kharma is very real and she is one mean b!tch.
#48071 11/19/01 01:47 PM
You can also try some "FREEZE IT" Used on cct. board chips! It makes the area really cold and might allow more play with plugs!(Shrinkage) wink
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#48072 11/19/01 07:00 PM
I've been working on AL headed engines a long, long time (30+ yrs.). I've done my own Duratec plugs 3 times now. NEVER EVER use anti-seize on spark plugs. Firstly, it impedes the transfer of heat from the plug to the head/water jacket. Secondly, using anti-seize causes an incorrect torque reading. The torque per the Ford manual is a "dry" torque. Using anti-seize gives a false reading.
Spray with WD40 or Liquid Wrench each day for a week. It will also help if you attempt to remove the plugs when the engine is warm, but not hot. Be very careful and use the correct tools. You should be able to start them. If you can get them started, but they're still tight, turn them in a little, then out a little, and on and on. Don't forget to blow out the plug wells with compressed air before removing the plugs. This way no garbage falls down in the combustion chanber. Use a properly calibrated torque wrench when installing new ones and you shouldn't have this problem again.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
#48073 11/19/01 07:07 PM
5 stars for you Brad! I also agree fully with not using antiseize. If spark plugs are replaced at regular intervals and "IMPORTANT" you don't park your car under water, then there should be no need for antiseize! wink
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#48074 11/21/01 04:09 PM
9
9
I used anti-seize when I put in my platnium +4's. Should I take them all out and wipe them clean? They are a huge PITA, so I dont want to take them out again unless I really should. And I try not to park my car underwater, but sometimes you just cant find a damn parking space! laugh Anyways, thanks for the help!! -Nick
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#48075 11/21/01 05:05 PM
If it aint broken, don't fix it!
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#48076 11/21/01 06:27 PM
What are the side effects of poor heat transfer?
Are the duratec heads aluminum? I'm pretty sure the zetecs are.
I'll stick with the anti-seize. But I am interested in hearing more about the detriments of doing so.
#48077 11/21/01 07:11 PM
Poor heat transfer could lead to damage to the plug as it will go passed the critical self-cleaning temp, to hotter than it should. It may crack the plug or it may wear out fast. Sound right anybody?
This much I do know......
Zetec - Aluminum head, Cast Iron Block
Duratec - All Aluminum heads and Block w/ steel cylinder sleeves
Well, I used anti-seize on my +4's with no problem. Mind you, I first applied the anti-seize, then wiped with a dry cloth to get most of it off. That leaves so small an amount, only that which is required to prevent corrosion, left behind. I was also told by a dealer and part time rally car mechanic for Team Subaru that if you do use anti-seize, use VERY LITTLE and use the bronze coloured stuff. Holds up better in the heat.
Just my .02 worth
Hope that helps.
2002 Nissan Sentra SE-R Spec V
Vibrant Blue - fully loaded
