Posts: 206 |
are these the double platinum ones or not. i asked the guy for them and they were 3.99 a piece. so im not sure if these are the right ones or not. i hope so, cuz i cant find the reciept. doh!
1998 Sport Contour, A4
2000 WS6 Trans Am, M6
Posts: 206 |
ok, the last number, 632FM is only a stock number... so i dont need to worry about that. now if i could only figure out the other numbers.
Posts: 305 |
i believe the NGK website has a link to a chart that shows what the number/letter combinations mean.
Posts: 635 |
The double plat's I have are the new number AGSF32PPM Ford's re-doing re-numbering????
32 has to do with heat range.
works great in my Duratec
Paul
That NGK site needs updating when it comes to the motorcraft numbers.
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 9,602 |
(F) Finewire single platinum ground electrode + (M) Nickle plated threads
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,044 |
Originally posted by chrisregets: ok, the last number, 632FM is only a stock number... so i dont need to worry about that. now if i could only figure out the other numbers.
I was at AZ this weekend and they have that plug listed as a replacement for the contour V6. We looked at the plug and it was easy to see it wasn't double platinum. Went to NAPA and got autolite double plats (APP764) for $4.99/each. I couldn't find Motorcraft AWSF32PP anywhere.
Posts: 9,602 |
Originally posted by tw0wheelin: Went to NAPA and got autolite double plats (APP764) for $4.99/each. I couldn't find Motorcraft AWSF32PP anywhere.
AZ carries the AWSF32PP plugs on the shelf. It's a normally stocked item ($3.99 each) Advance carries the Autolite APP764's for $3.99 each.
2000 SVT #674
Posts: 21,197 |
It has to have the PP for double plat.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
