#431222 09/07/02 05:23 AM
1996 SE and 1996 GL with a chirping sound comming from fan blower under the dash. Only when on its lowest speed. Sounds like crickets!
Seems to be a ford thing! Had the same thing on my Escort.
It is starting to drive me nuts! Is it the bearing or something?
How hard is it to get at the blower? I had a look under the dash with the glovebox removed and it looks like quite the job.
Any advice?
------------------------------------------------- 1996SE sports package, Duratec MTX No mods yet. 80K Kilometers. ------------------------------------------------- Wife has 1996GL Zetec ATX.
#431223 09/07/02 05:34 AM
Ford: Quality is job 1...the 1 right after screwing over the customer
#431224 09/07/02 01:06 PM
H
H
In Ford's defense, my GM '90 Buick also has this problem, but its blower motor is PITA to remove(ps pump interferes with extraction).
Contour - From under dash behind glovebox, disconnect wiring to resistors, lift retaining lug and rotate motor 30 degrees counter-clockwise to remove. (from service manual, haven't done myself.)
#431225 09/08/02 01:33 AM
4
4
Have the same problem with my '95 GL, my solution: Tune into local hard rock station (in my case, Q107 in Toronto), crank 'er and pray that they play Led Zeppelin Immigrant song or something similar!
Totally stock Fix Or Repair Daily '95 GL Extent of mods: Pioneer 6x8's up front to replace crap stock speakers and a host of oil stains in the trunk....oh yeah, and a trailer hitch too!
#431226 09/08/02 01:45 AM
oh my god here we go with the ford bashing again...does he ever quit??by the way you act as if only fords have problems,and only ford dealers suck,which isn't true ALL CARS have problems(hence they all have service departments,and parts counters)and ALL CAR dealers suck!just the facts
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#431227 09/08/02 02:47 AM
I plan to go after the problem and will post a solution.
If there is any more advice on removing the blower then please let me know.
#431228 09/10/02 05:54 PM
I had the same problem with a warranty fix. I didn't think that they would find it, because it happens imtermittently. I must be lucky with my ford dealership in Houston. Anyway, enough on that.
Getting the blower motor out is VERY easy. It takes about 5 minutes.
I can't remember if I had to remove a trim panel from underside of the passenger-side dash. anyway, the motor has two latches to disengage, then rotate it counterclockwise about 1/4 turn. It will then slide straight down. Very simple to get at.
Good Luck,
David
