#47993 11/17/01 09:09 PM
gbtmwe Offline OP
Anybody ever had a problem with a leaky trunk?? I have a 99 SE. It seems to me the water is sneaking around my weatherstripping, but I took it to a dealer and they are telling me the tail light is leaking. I can't find a leak in the tail light...
1999 Contour SE 2.5 V6
#47994 11/17/01 10:52 PM
Get a flashlight and a trusted friend and look for the water leak. Climb into the trunk with the flashlight while your trusted friend runs water from a hose all around the trunk and tail lights. Usually you can find the leak this way with a little patience.
Trunk seals can leak, and so can tail lights. It is all speculation until you test it.
Jim Johnson
98 SVT
#47995 11/18/01 12:28 AM
I found a leak in my 95 contour which was in the trunk. Apparently the inter panal within the trunk has a retangular plug that fits into the panel to plug the mold hole from factory. The one that was there cracked and fell out allowing water to enter the trunk around the tail light.
#47996 11/18/01 12:52 AM
F
F
Leaks at the tail light gasket is quite common. I had the same problem.
#47997 11/18/01 02:24 AM
i work at a ford dealership, and we've had a couple of contours come to us with a trunk leak. Each one was infact the tail-light.
96 Mystique "Spree" Duratec ATX
"They have the Internet on computers, now?"
#47998 11/18/01 08:37 PM
My 95 Mystique leaked around the tail light. They replaced the weather stripping around the tail light and voila no more water dripping on my head when I reach in to get my groceries. This was apparent within about 6 months of buying the car new.
Judie
#47999 11/18/01 09:48 PM
Mine leaked at the fresh air vent box just infront of the tail lights. Pull your trunk liner back, it's about 6-12 inches infront of the tail light. To check it blast some water up in the vents (you'll see the slits just infront of the tail lights)
99 Ford Contour SE Sport
Manual V6
SVT front/ rear bumper /w Aussie grille
Jet black
Premier DEH-P740MP head unit
matrix display, plays Mp3s!!
800 watt Kenwood amp
2 12" Polk Audio subs
Blue "euro" headlights
Eibach Pro-Kit springs
17" Enkei RS-5
White Indiglow gages
#48000 11/19/01 01:53 PM
Get some of that black RTC or whatever and put a fine bead over top of back light assembly. Mine was noticeable shrinkage of that black seal. After black bead (no me problem) $7.00 at hardware store!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
#48001 11/20/01 01:21 AM
Haha, or make sure u have a 4 button key fob! laugh
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
