Posts: 34 |
I was coming down a hill today on campus, breaking a little bit and the all of the sudden there was this awful howling noise from the front left. It sounded like something was rubbing against something else, but I have no clue what. It sounded horrible!!! I've noticed a small rubbing sound at slower speed lately, but nothing like this. Anyone have any clue what it is? Also, my right breaklight is broken, looks like someone/thing hit it, red glass on the inside of the light with a hole about 3-4 inches wide. How much will that run me to replace? Such an awful day!
Rob T.
95 Ford Contour GL
Zetec Engine
Inherited from my dad, so no mods at all. One sweet ride though!
Posts: 40 |
not sure if this is the same thing as your problem, but I had a noticeable groaning/rumbling from front left recently. Shop diagnosed as wheel bearing in need of replacement. Estimate was $225 but folks seem to think that's a bit high.
Jason
current 95 Contour SE (V6) MTX owner
former 96 Mystique LS V6/MTX owner
Posts: 1,459 |
I recently replaced a front bearing. It moaned, or groaned, or howled, when I was driving forward, or to the left, but not when I went to the right.
Could it be a brake problem? You mentioned you were braking when you first noticed it.....worn brake pads can make a lot of noise....
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 18 |
Pep Boys will do it for about $130.
GalaxyEng
95 SE MTX Electric Red
2001 Corvette Z06 Torch Red/Z06 black
2000 Lightning Red
2003 Jeep Liberty
Yes, I like Red Cars!
Posts: 970 |
See if your springs are okay...
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
Posts: 1,616 |
Howling...from springs....yeah, check your antenna too...
Wheel bearing...PM TH and see if you can do it your self.
Posts: 34 |
Who is TH? If TH reads this, IM me on AIM if you have it please, thanks! SN: EnronCFO
Rob T.
95 Ford Contour GL
Zetec Engine
Posts: 1,603 |
Originally posted by GalaxyEng: Pep Boys will do it for about $130.
I'd rather have FORD work on my car BEFORE Pep Boys came anywhere near it.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 1,044 |
FWIW, If you can't identify a rub causing the howling sound, it may be the infamous 'moose'. This is caused by a resonance in the air intake and sounds like, well, I guess a moose groaning. There is a TH fix listed in the how-to section that typically clears this sound. The moose usually shows up as the weather gets colder. I think I cleared mine, but wont know for sure for another month or so...
Posts: 40 |
It could be the moose, but I'm guessing not. As you said, moose is more common in colder weather - probably not cold enough yet in NY state if that's where the car is.
I think of the moose as a 'hooting' noise, almost like a foghorn in the distance.
Jason
