#6528 03/23/02 12:16 AM
I'm thinking about getting a 1985 toyota supra as a beater car. the guy selling it says it needs a clutch. it started on the first try, the moter seems good for 150,000 miles. When i put it in gear i get nothing, no noise at all, no grinding and no movement. if it is just the clutch i'll buy it this weekend for only $300. carparts.com has a clutch kit for about $150. i just want to be sure it's the clutch and not a bigger problem like the transmision. any advice would be great, thanks.
91 Honda CRX
Bilstein shocks, Tenzo R springs
96 Ford Contour LX V6 ATX
KKM intake, Ford Motorsport 9mm wires
All Kenwod Stereo System - 134db
KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
E
E
All i can tell you is i once had a 83 celica and it did the same thing. I thought my clutch was toasted, so i pulled the transmission and to my suprise the (pivot bolt) that the clutch fork pivots on had broken. The repairs costed about $3.00 and a little bit of my time.
Hope i helped good luck dude......... :p
98 LX,
Eibach`s ....
ICWrims / Potenza`s....
Svt kit w /duals...
BASF Extreme Ocean paint( complete color change)....
Bullit gas door....
Fuba DSM rear mount roof antenna....
Pre 98 trunk....
Blacked out headlamps, W/ Eyebrows....
A6 Side markers....
Shaved antenna and deck lid lock...
4 wheel disc brake conversion....
Magnaflow resinator....
SVT gauge cluster....(Yes the SVT gauge has a O/D light)....
Complete mesh grill treatment, Not gutter guard....
Titinaum window tint....
Burgman custom Power window & lock conversion....
More to come as soon as i complete this one.
Yeah its a LX but it has a 2.5 and it looks better then your ricer smile
