Originally posted by serge_loranger:
how should I go about wiring the illuminated part of the ring
Since you want it to work off of dimmer, the easiest would be to parallel with gearshift indicator light since you will have console off. OEM on my '97 is actually fed from behind dash. Like your's my '98 does not have this feature.
Above for atx, since you have mtx you'll probably find an unused connector. Light uses the w/gn for +12 and bk for ground.
