#429146 09/05/02 12:51 AM
Will 98 SVT cams work with the 01+ 3L Duratec? Heard different thoughts on cam gear size and what not, just wondering if somebody can spell it out in a few sentences of if it will work (drop in) or if something else will need to be modified in order for them to work correctly?
Thanks.
Jon - NJNECO - Simply Domestic 2000 Silver Frost Cougar v6 MTX Dyno Tested 173.6 whp - 161.2 wtq Visit www.mastamoon.com for Details!
#429147 09/05/02 01:02 AM
No modifications necessary. Use all of the timing components from the engine with the 98 cams (large pitch 3/8"). The 01+ 3.0L Duratec will have the smaller pitch (8mm) cams and associated timing components.
Read my post here a few times and you'll get it. Let the cams dictate which set of timing components you use.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=3L&Number=10522&page=0&view=collapsed&sb=5&o=14&fpart=1&vc=1
#429148 09/05/02 01:10 AM
Thank you.. Does my 00 cougar built 12/99 have the larger or smaller or larger pitch timing stuff?
#429149 09/05/02 02:59 PM
like i mentioned on NECO, my only real concern would be different cam lobes for primary vs secondary valves, whereas the 3.0 has a common port in which the primary and secondary valves work in perfect sync...
2000 Cougar V6 MTX 2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN Nearly all suspension mods Big ass stereo ...and more... See Her Here
