#47927 11/16/01 06:50 AM
brent Offline OP
I own a 98 v6 contour and lately it has been acting up. A few times when i have put it in reverse (morning mind you) it is as if it is neutral. When I am on the freeway, the RPMs hang around where they would be if overdrive was on?!?! Also, I often cannot push the car past 4500 rpms, its acts as if a governor was on it. What the freak is going on. I have checked tranny fluid so that is fine. Any help is very much appreciated!!!!! Thanks
Black 99 SVT
Ground Control Coilovers
19" KMC Tensions (Gunmetal)
Silver 98 SVT
19" KMC Suicides (Flat Black)
I don't think it is your transmission that is causing your problem.
It sounds like it could be the Neutral Saftey Switch.
This is mounted on top of the transmission.
If it is loose or broken, the PCM won't know the correct position of the transmission gear selector, and will cut off your spark at over 4000 rpms.
Pete...
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
