#47902 11/15/01 06:23 PM
I need to know how to change the inner tie rod (connecting rod).someone please help.
James Good
98.5 SVT Contour
Mods hell I cant aford any mods
It's too much money fixing Ford's mess up's
#47903 11/15/01 08:01 PM
'Inner tie rod'???,front suspension steering rod end ? rear suspension lower arm front,lower arm rear,'tie bars-rear?Confused,where is it exactly?
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#47904 11/15/01 10:27 PM
front right side inner tie rod end, hell that all they told me at metro 25 and the wanted 350.00 to do it I went to get a alighnment and they said they could not do it cause I had a bad right side inner tie rod end.
James Good
98.5 SVT Contour
#47905 11/15/01 11:55 PM
There is only one tie rod end,that is the balljoint on the end of the rack side arm that attaches to the steering knuckle,the 'true' inner is a balljoint under the bellows of the steering rack and I doubt that is worn!It takes about 20mins to change both sides then alignment time,350 is BS,go to another shop!
V6 MTX
#47906 11/16/01 07:34 AM
F
F
The inner rods do wear out. It took me about an hour to do each side. The plastic boot needs to be removed to work on the RE&RE of the inner rods. I also replaced the outer tie rods of course. Then I got a Toe in check and adjustment, which is all you need to get done at an alignment shop. Allow 3 hours to start and finish.
Oh yes and by the way it takes longer than 20 min. and futhermore $350. sounds about right if you have it done by the dealer.
smile
#47907 11/17/01 03:12 AM
Thanks guys, I know what I'm doing sat.
James Good
98.5 SVT Contour
