#427314 09/02/02 10:18 PM
Hello,
My zetec is getting the error: p0302 mis
p0302 Cylinder 2 misfire detected
Does anyone know what will cause this error? In the last couple days the car has been idling very rough and stalls on start... then today it blew that code.
Anyone seen this?
Thanks!
- 2002 Focus SE Wagon - 2002 Mustang GT flows/k&n: 13.95/101mph - Former: 98 SVT, 96 Mystique - North Georgia Auto Forums
#427315 09/02/02 10:31 PM
F
F
Plugs, Wires, Coil Pack. Could be any one of those, probably plugs or wires though. If your car has high mileage on it, you should probably change them anyways.
That would be my guess anyways.
Simon new- '04 Dodge Dakota 4x4. V8, 5spd FOR SALE Black 98 SVT EO (#2119 of 6535)- SOLD! New project-'88 Ranger 302 swap.
#427316 09/03/02 01:02 AM
From the Ford TSP (Technical Service Publication):
Possible causes:
-- Ignition System.
-- Fuel Injectors.
-- Fuel Pressure.
-- Evaporative System.
-- Canister Purge.
-- Base Engine.
-- Running out of fuel.
#427317 09/03/02 01:16 AM
Thanks guys.
Iâ??ll start with the cheap stuff and move on, if needed. It feels like a spark problemâ?¦ not fuel.
#427318 09/03/02 02:49 AM
I recently fixed a misfire code on my in law's 96 Bonneville (sorry, no blower), same wasted spark type ignition. It had a bad coil and a bad plug wire, both confirmed with ohmmeter (chicken and egg situation there probably). Nice thing about GM coils - you can replace individual coils, instead of the whole coil pack assembly.
#427319 09/04/02 12:31 AM
Fwiwâ?¦
It was the plugs. I replaced them with some motorcraft double plats. The problem plugs were autolite double platsâ?¦ they only lasted 30k.
The car is back to running normal
