Page 2 of 3 1 2 3
#47787 11/15/01 02:06 PM
Funny this topic comes up just as exactly the same thing starts happening with my car (99 SVT, approx 20K miles) and I come looking for answers. smile
I'm quite certain this is not the classic 'throttle hang.'
This 'hanging rpms' started quite suddenly yesterday. If I'm cruising along a parkway in 4th around 3,000 rpms, I can take my foot off the accelerator, and it's like it's on cruise control...the rpms will stay there forever.
At a stop, it takes forever for the rpms to drop back to idle, if they ever make it that far before the light changes.
A couple of times, I've pushed the clutch in and watched the revs actually go up a few hundred.
I'll suggest the dealer start with the TPS.
-Craig
Craig
99SVT black/tan
2725 of 2760
#47788 11/15/01 04:09 PM
Q
qaz Offline
Q
The TPS is about $25 and 5 minutes to replace, or "much cheaper to replace than to diagnose".
Bill Jenkins at Sentry South LM can probably get it cheaper...$25 was from my local Ford dealer.
Brian
#47789 11/15/01 05:29 PM
I would really try cleaning the throttle body first before changing sensors. It probably needs it anyways. My car has almost 70000 miles on it now and I know that The throttle body needed to be cleaned around 30000 miles because the throttle was sticking.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
#47790 11/15/01 05:38 PM
I had the same exact problem and the dealer found out my MAF went bad. Once replaced, all was better! smile Good luck explaining it to the dealer, if you're under warantee. They had my car for 2 days trying to fix my problem. I know it wasn't TH, because when I pushed the clutch, the revs rose. I would be sitting at lights at 4k rpm.
Chris
NJ
98.5 SVT Silver Frost w/Frankentrans
carsla AT optonline DOT net
#47791 11/16/01 01:44 AM
I have had all of these problems, RPM sticking and RPM rise. When I took it to the dealer they found that the IAC valve solenoid was bad. They replaced it and the car drove like a dream for less then 2 months, and now the symptoms are coming back.
I don't know what to do because the car runs ok in the cold, but when the weather gets warmer, that's when it starts acting up again. With winter coming I don't know if its worth taking it to the dealer.
Kamil
99 SVT ~ "Black Beauty"
#2362 of 2760
DOB: 7/28/99
So far...
-20% tint w/ front tint strip
-Ding guards removed
-Fog light mod
-Alpine CDA-7875
-2 MTX T6000 12's
-MTX Thunder4202 amp
-FMS wires w/ Bosch +4's
-Mobil 1 ATX
#47792 11/16/01 05:31 PM
My sticking/rising RPM problem lasted for two days.
Everything returned to normal at the usual time....on my way to the dealer to have it checked.
The suggestion from there: If and when it happens again, and you're in the neighbourhood, stop in and see us, and leave the car running.
I guess it's the best they can do for now.
Craig
99SVT black/tan
2725 of 2760
#47793 11/17/01 04:59 PM
Ain't that how it always goes? confused :p
Black/tan early '98 Contour SE Sport; V6, MTX, loaded
Kenwood KDC 316S CD deck; aux. dome light mod; trunk popper spring; resonator bypass; hood strut mod; SVT grille; Continental tires
Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
#47794 11/17/01 05:21 PM
So many suggestions, not sure what do do first
1998 T-Red CSVT (1492 of 6535)
Born on 5/30/97
KKM
4.6L TB with custom "Throttle Optimizer"
Bassani Exhaust
NP-Tuning Sniper Intake Pipe
Fog Light Mod with 885's
Clear Corners
Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
#47795 11/17/01 06:47 PM
E
EWF Offline
E
A competent mechanic with the right equipment should be able to check all of the items mentioned. Find a shop with a scope. Engine codes can only go so far in diagnosing problems.
#47796 11/19/01 11:59 PM
V
V
My '98 E1 SVT does the throttle boogie, and it has since day one. Sometimes it will hang around 35000. Other times it will hang and sloooooowly drop to idle. At times it even climbs from 3500 to 5000rpms. Gulp! My car has been check and checked again. Funny thing is, it never happens at the dealer. It comes and goes, so I don't sweat it much. I've learned to live with it. Now....if someone steals my car......he he he! Watch out!
1998.5 Contour SVT - Silver Frost Metallic/Midnight Blue - 64K miles.
Page 2 of 3 1 2 3
