a friend of mine was misunderstanding the 3.0 swap and came up with the question... what happens to a 2.5 with the 3.0 heads? does it raise/lower compression? what effect do the larger valves have? IS THIS EVEN POSSIBLE?i would do the math but i don't have the bore of the 2.5 or the volume of the combustion chamber on the 3.0 so figuing out the compression ratio is out of the question unless i can get this data. Anyone got an idea of what might happen here? And how would the 3.0 heads oval ports work with the 2.5 intake manifolds? I don't think im beating a dead horse with this question, Just trying to find out some possiblities
