Posts: 206 |
which of the two is better. i have a friend that works for rousch performance and he says NKG. i thought the autolite double plats were better. he says no though... whats everyone ones opinion here. TIA.
1998 Sport Contour, A4
2000 WS6 Trans Am, M6
Posts: 5,854 |
autolites are what the car comes with from the factory (motorcraft and autolite are the same plug). Nothing wrong with that IMO.
1999 Silver Frost SVT
#609 of 2760
Posts: 1,361 |
I dropped in the Motorcraft Double Platinums and am very happy with them.
'98 SVT Contour, in at least 639 pieces
4 Speed MTX...synchro and shift fork replacement in progress
Posts: 368 |
I'll just say, Autolites have no comparison to NGKs. As an NGK, Denso and Autolite dealer I'll say that NGK tops them all when comparing Platinum. NGK uses a larger amount of 100% Pure Platinum on both there center & ground electrode. Another great design is there center electrode tip is laser welded making for precise fit and finish and it's a fine point requiring less voltage to spark. That's the reason you pay an arm and a leg for them. At $12.50 a pop, it's no reason why there's is the best.
Posts: 6,760 |
I ran the NGK plats for awhile and loved'em. Then I couldn't get but one at Advance cuz they discontinued them..
But I'd stick with the Auto DPs or Motocraft DPs
Ryan
Trollin!
Posts: 2,857 |
i'd go with the autolite's..just put the double plats in mine,and they are great...why spend that much more for the nkg's..i seriously doubt a spark plug will make that much of a differencs..its not like nkg's add any hp or anything..with the autolites you'll get great performance and save a few bucks over the nkg's in the process...
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
Posts: 5,854 |
precisely
#609 of 2760
Posts: 1,541 |
The cheapest double plat plugs from a quaility manufacturer is what you want.
Posts: 4,713 |
Originally posted by TedS: http://www.grassrootsmotorsports.com/stock%20tips.html
read the entire article, but there is a good section on Plugs as well...
it is interesting
agreed...very interesting. the author(s) were very objective and made sure they pointed out that it worked on some and didn't on others. good article indeed.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
