#419233 08/23/02 05:31 PM
I
I
I want to know if there is anyone else out there going for the 3L in a 1995 tour. If so please get in touch with me, I need to know what I am expecting for this all. Thanks in advance.
------Travis------ "I'm driving 100 on the highway, so if your doing the speed limit get the F*** outa my way"
i will be doing this very very soon. well, i wont be doing it myself. the 3.0 plus a few other things will be getting done for me. all i need is an estimate which i expect any day now and then things start to happen.
Oo (xxx)oO o xxxxxxxx o
Y
Y
Yeah I plan on doing it in the spring. I have been watching information on this for awhile. Your best bet is have Brad Noon do it.
Yankeyspeed: American power and ingenuity 95 SE -Stock enough to be overlooked, Quick enough to hold it own. Now driving a 2001 PT Cruiser
I
I
okay is there anyone actually in the midst of doing this, and I plan on doing it myself due to cost.
i wish i had the know how to do this myself, but i know my limits and this type of major swap is too much for me. i would like however like to be there whn a lot of the work goes on so i can learn as much as possible. peace.
You know I am.
any day now.
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
does anyone have terry haines' telephone number? i seem to have misplaced it. thanks.
Okay, heres all the stuff i can think of off the top of my head, it has mostly to do with the fuel system. What you need is at least a lower intake manifold from either 97 and up contour or a taurus from I think 97 to 99. Next, you need a top loading fuel rail from one of the newer contours, it needs to have a return line, so 97 or 98 will probably be the only ones you can get that from. Next, you need at least 19lb injectors, and may have to solder new wiring harnesses on to fit the injectors. I would recommend a higher flow fuel pump. I would also recommend an upper intake manifold thats been extrude honed. In addition to all this, you may have to modify the exisiting fuel rail (the one that goes from the fuel pump to the manifold) because its probably going to be just a little bit short. If you have any more questions, just PM me or drop me an email at pwoodwar@gmu.edu and i'll try my best to get them answered.
by the way, when you install the new injectors, you also need an MAF that is calibrated for them.
