#418847 08/23/02 05:23 AM
I dont know if all contours alternaters are behind the wheel well buti know the svts are, i was driving mine today and it was raining and i was forced to go through a few puddles, and when i went through them i thought my car was going to die, the battery light came on and the car almost stalled,does anyone know if theres anything i can do to keep it from getting wet
98 csvt-sold 98 honda accord lx
#418848 08/23/02 10:38 AM
Your serpentine belt might have gotten wet and slipped. This would cause a loss in power. Was there a high-pitched screeching sound? You might want to check if the belt needs to be replaced.
#418849 08/23/02 01:06 PM
The alternator, PS pump, and AC will each stall if the serp belt gets wet. Happened again to me yesterday while taking a corner. Scared the jeebus out of me (like always).
-06 GTO Torrid Red/M6 -98 LS with BPU -05 Honda Odyssey EX-L mv .zig ..\for\great\.justice
#418850 08/23/02 08:43 PM
I'll swear my AC started blowing colder after changing the serpentine belt.....
98 Silver Frost SVT 97 BMW 540I Sport, six speed "Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future" "A coveted car should never stunt your life, but should make it more rich and interesting."
#418851 08/24/02 02:01 AM
You may want to check if the inner fender liner/splash shield is in place.
If you can see the crank pully from under the fender, than it is missing.
It needs to be in place to stop the water from splashing on the belt.
Driving through miniature lakes is something totally unavoidable.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
