Posts: 166 |
I'm a member of FordTruckWorld check out some pics of my beat up 'ole truck at http://www.fordtruckworld.com/mygallery.asp?id=4930
Love for my click...
Representin' Everywhere I go...
Posts: 21,653 |
I haven't heard much bad about Fram filters. My question is, can I use the heavy duty filter? There are four types and this is a step up from the bottom one. It has a 98% single pass rate and 96% multi pass, compared to the others 96% and 94%.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by FordTruckBoy: Wow... That's kinda scary, I've been use'in Fram filters for quite a while (execpt on my truck she get motorcraft) and I've never had a problem. I've never heard any storys about Fram filters failing... What happens? How can you tell?
Same here.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 8,301 |
Wow, I guess I will get Motorcraft from now on. I cant afford the risk.
-Ken V.
psycho_bass@hotmail.com
Posts: 6 |
PART TYPE NOTE PART # PUREONE Oil Filter PL24651 Oil Filter L24651 Air Filter A24859 Air Filter Cabin C14860 Fuel Filter F63169 Breather Element N/R PCV Valve PV152 Transmission Filter CD4E N/S
Here are the Purolator Parts numbers for the 2.5L Duratecs. I use the Mobil1 5W30 SuperSyn Formula in mine. It likes 6 quarts as opposed to the 5.6 quarts it's supposed to carry. I get better overall gas mileage and a heck of a lot lower running temp. Gas mileage is NEVER less than 24 MPG in the city, so it must be helping out a lot.
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 682 |
Originally posted by Kremithefrog: I haven't heard much bad about Fram filters. My question is, can I use the heavy duty filter? There are four types and this is a step up from the bottom one. It has a 98% single pass rate and 96% multi pass, compared to the others 96% and 94%.
The last time I heard, Fram's heavy duty filters use some of the same cheap crappy cardboard interior parts that their basic filters do.
Posts: 126 |
I've been using a Fram for 16 years. I may consider changing after hearing all of this. I use Castrol oil and get 26.7 MPG out of my Duratec no matter what. I don't jack up my car (SE, not lowered, no suspension mods) when changing oil.
Posts: 1,840 |
For those that want to go w/ a Motorcraft filter, it's # FL200.
Posts: 21,653 |
i will be changing oil soon.. i have like a couple hundred miles more.. so the plan is to get the motorcraft filter and mobil1 5w-30 syn.... i have no jack stands or ramps and figure i probably will need to get it up some... can i just jack one side up? (i can right) i can put wood to support car if it happens to fall...any more tips.. this will be my first time changing oil myself,, though i've seen in done on other cars.
98.5 SVT
Posts: 16 |
I can't believe the effort you guys go through in changing your oil just to avoid taking the wheel off.  I've done over 20 oil changes on my tour over the past 3 years and every time I take the passenger wheel off, I've now got the change down to about a 20 minute job from tire-off to tire-on. Also, with the tire off you can put a peice of cardboard bent in a V-shape under the oil filter and direct it down in front of the A-arm to channel the oil into the drip pan. I barely ever get even a drop of oil on the boot, frame etc. All this and I don't have to twist my arm and wrist out of shape!
Totally stock Fix Or Repair Daily '95 GL
Extent of mods: Pioneer 6x8's up front to replace crap stock speakers and a host of oil stains in the trunk....oh yeah, and a trailer hitch too!
