Ryan M. Offline OP
Just a general question about the electricity going through these Duratec alternators. I had mine rebuilt for about $150...needed a new transistor, and two other parts I couldnt even pronounce. The guy said he had to RESOLDER the connections to the alternator again cause I melted it so bad. I feel kind of proud in a way. I'm only running a small Legacy Audio amp that only puts out about 80watts RMS. I don't currently have a fuse on the power cable from the battery to the amp. But I also have 9mm Ford Motorsport wires going to Bosch Platinum +4s. So I was wondering, since my sparks are being driven by high performance parts, does that put a damaging amount of strain on the Duratec alternators? Thanks guys.
Ryan M. Taylor
1996 GL V6 ATX Desert Violet
{__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __}
http://rmtaylor.webhop.org
AIM: Vinnland990
Dude...
Two words and a hyphen.
In-Line Fuse
Kharma is very real and she is one mean b!tch.
Alternator has nothing to do with Spark Plugs or Ignition Wires. Just keeps your Battery happy.
99 SVT Black/Tan #1090/2760
82K Miles.......B&M Edge Shifter
Mobil1 5-30.....Side Markers
Ford Synth MTX # XT-M5-QS
Locking Lugs....Cup Holders
Black Sail Panels...TH Fix
Aluminum Gas Filler Door
BS Potenza S-03's
KVR Cross Drilled Rotors + Pads
Dual Mode Damper - soon
Clarion head unit
Pioneer 2-ways
Second the fuse thing. Cheap and you can buy a dozen as extras!!! wink
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
