According to the Ford TSP (Technical Service Publication), it seems to depend if you have an automatic or manual transmission.
For a manual transmission, it says to remove the air cleaner assembly (aka air filter box), so it must be under there.
Not sure where the one for the automatic transmission is.
Hopefully, someone else will be able to help out.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
