E
E
I'm getting a noise. The sound is like an electric motor under a load. It corresponds to engine speed. Cannot hear it while driving even with stereo off. But at stop quite noticeable. A rrrrrRRRRRRRRRrrrrr whining sound. My guess is the alternator. But is it just getting wierd or is it getting ready to DIE!!!! With the lights off the noise is almost imperceptible. Just curious. ????
One beat'99 Tropic Green SVT
Worn alternator brushes?
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Do you have an aftermarket stereo?? amps etc.. Try checking your grounds or your gains on your amp (if they are turned up to high you get wine) and a bad ground will also cause this. just my two cents smile
96 teal contour
nothing yet but im saving
E
E
?? grounds?? sounds worth investigating... thanks
I was thinking EMF interference too.
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
maybe someone got ya a blower for christmas and installed it for ya. laugh
does it make the noise when the radio is on? off? that will help narrow it down.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
As Terry H. mentioned, possible worn alternator brushes. Another possibility is scored commutator or worn bearing that allows rotating element to contact the field coils & generate the whining sound. Replace alternator.. OR...
could it be a low fluid level in the power steering pump reservoir?...just my $00.02. laugh
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
