Posts: 79 |
Three possibly unrelated problems, but they started at the same time.
1. When braking or accelerating, there is a decently loud clunk. This only happens once, like if you apply the brakes, get a clunk, you won't get another one until you start accelerating. Kinda like something is shifting from the front to the back. 2. When applying the brakes, they make a nasty noise like plastic is rubbing on the wheel/rotor, and it is related to wheel revolution. 3. When I turn the wheel slightly at around 35mph or greater, there is also a revolution related grinding that you can feel in the steering wheel/floorboard and it gets worse the further you turn the wheel.
I'm thinking maybe a motor mount for the clunk, but it started the same time as the rest of the problems. any help would be appreciated.
Mike
Old - 95.5 SE with lot's of mods. New - 98 Black SVT with few mods.
Posts: 1,847 |
Motor mounts, worn or broken suspension parts, loose wheels, wheel bearings....
In short, a lot of things could cause that.
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
Posts: 2,481 |
Sounds like your ball joints have lost its lubrication. If you dont have a Haines repair book, I would suggest you go out and get one for $20 bucks. But, if you have received one problem without fixing it, other problems will eventually come out of no where.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 184 |
what exactly is the motor mount? i get a clunk too..when i brake and when i acclerate after i brake. Thanks!
alicia 96 tour 2.5 auto :p
Alicia 96 Contour LX 2.5L V6 Duratec DOHC Stock of course! BAD ASS GIRLS DRIVE BAD ASS CARS!!!
Posts: 79 |
Thanks for the response. Wheels are all tight, I checked the motor mounts and they are fine. I'll check the ball joints, but if not that I'm thinking maybe a suspension component. Thanks again.
Posts: 112 |
Hey try checking drive shafts for boot tears and lack of lube in them...probally time to rebuild them...another cause could be the Rack and pinnion steering sys.. I heard this sound before in a car I work on before it was a Driveshaft both of them....email me the cause if u find out for FYI rubie132@hotmail.com
Posts: 219 |
Hey Mike,
That grinding you hear/feel in the steering wheel may be a problem that I had. My front Sway Bar is loose and I a noise from the front end that I feel in the steering wheel. Haven't fixed it yet, but if you do a search you'll find what you need on it. You can check it by seeing if there is any lateral movement in the bar. There shouldn't be.
- Zack
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
Posts: 974 |
Wheel bearings! For grinding while turning thingy! Def. Wheel bearings
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
