Originally posted by Pac Man:
Hey, what do you mean you had the "fix" done?
Ford has two options, one is to repair the original dash by re-gluing it and putting a plastic strip across the end of the dash along the windshield or they can replace the entire dash if they feel it is necessary. My dash was curling up and the defroster vent was popping up. They just "fixed" it without replacing the entire dash.
There is a recall for your dash, it will be done free of charge. If the "fix" is done then it will only take a couple hours. You shouldn't need a rental. If they need to replace the entire dash then one will probably need to be ordered. That could take quite a while but actual installation shouldn't take too long I don't think.
