Posts: 592 |
Where did the guys running a wet n2o kit find a fitting that properly fits on the scrader valve???? Its not the same as the mustangs from what I know.
Ryan 98.5 Silver Frost Tour SVT 5979/6535 Born: May 15, 1998 Some Mods, still not fast enough.. 90 Black SHO
SVT Performance.Com
Posts: 972 |
I dont know anyone who has a wet system on their svt cept for you! one guy had a NX 100 shot but i dont know if it was wet or dry, and cant remember his username also.. can you clarify what a shrader valve is for the newbs
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 102 |
its right below the throttle body there should be a black cap over it. the schrader valve and fuel line is like crome or polish. or shiny at that. the fuel from the schrader valve to the solinoid fits perfectly no adapters. on a returnless fuel system you have to run a wet system. not dry. let me know if you find it...
1998 SVT Silver Superchips Exhaust 4" tips Short Throw shifter B&M Nitrous Kit by NOS rims by ATP wrapped in Toyos and 10" audiobaun hoodpins coldair intake
Posts: 102 |
part number for nos i know is like nos5040 or nos4050.....its been a while. so the fittings on that perfectly fit. but should of gone with the jets that slip on to the fuel injectors. its just a pain on were to put the disturbution boxes. and solinoids.
Posts: 592 |
is that the $40 or $50 fitting I've seen in summit?? There isn't anything else that will fit it?? We had a rubber fuel hose connected, but when I put the kit back on I want it done right and looking good. Originally posted by sicksvt: part number for nos i know is like nos5040 or nos4050.....its been a while. so the fittings on that perfectly fit. but should of gone with the jets that slip on to the fuel injectors. its just a pain on were to put the disturbution boxes. and solinoids.
SVT Performance.Com
Posts: 86 |
Contact Ritter Engineering, a supplier of Parker Hannefin parts and fittings. They don't really deal with automotive but they have every fitting imaginable. It may take a bit to come up with a part number but give it a try. 724-452-6000
stock 1998 silver frost SVT E0
Posts: 102 |
did you find the schrader valve if so the fitting sould fit right on. oh i was talking about the nitrous jets. they have nitrous jet that fit below your fuel injectors. instead of drilling your runners on your intake manifold.still mixes your fuel and nitrous you should have every thing you need. what kit do you have. it should be okay the hose you are talking about. but the nitrous hose shouldn't be replaced. well unless its damaged.
Posts: 592 |
Kit is homemade. I haven't had time or money to play with the kit anymore. As of right now its off of the car. I know where the scrader valve is like i said earlier looking for a fitting for it.
SVT Performance.Com
Posts: 527 |
Call me at Cerra Racing (866.869.5270) and let me find you something...Ask for Jon and mention CEG...
Jon
Posts: 592 |
will do, once I get some cash flow coming in...Thanks!! Originally posted by JFolker: Call me at Cerra Racing (866.869.5270) and let me find you something...Ask for Jon and mention CEG...
Jon
SVT Performance.Com
