thanks for that profound bit of wisdom 1turbofocus, especially since I thought that was what I just said . . .
seriously though, Terry is right, in that MAF signal vs. load (TPS signal) only gives enough resolution for low boost or street driven setups where yu are inherently conservative anyway.
Rara the timing tables are set up on load vs rpm so the ecu ALLWAYS knows as to the incoming air as to what the load is
so they do not show the same
woohoo, no wonder, seeing as how the stock PCM is
load-based.
and actually, as far as the MAF is concerned, they
DO show the same. The MAF merely delivers a single voltage signal to the PCM. The PCM combines that w/ a TPS signal to determine load, and then looks the two up on a timing table. Though I didn't go into too much detail before, that's the same thing I said above.
I am useing the stock ECU and just a chip to run 326hp at the wheels and a set of 96lbs injectors w/ a 70mm ported mass air
fantastic, you want a cookie? I mean your numbers sound good for a focus, no doubt, but it doesn't surprise me in the least. I have always said that the factory Ford PCMs are a wonderful thing and the ideal setup for a street driven car, IF you have the means to tune them properly for a particular setup. I have seen the Ford EECs do wonderful things for cars you would never suspect of still using the factory PCM. For you, the limits come in where the capabilities of the chip you are using, and the ability of your calibrator/tuner drops off.
But there is no doubt that for a full-boogie-squeeze-every-drop-of-power-out-of-the-tune-you-can you really really need a manifold pressure signal for the PCM to do everything right (and somehow, every setup terry talks about, ends up reverting to this level no matter what
