Posts: 104 |
Alright, I did a little looking around (actually I'm just trying to hit 100 posts and needed something to post  ), and Demon, I think you're wrong. Every single place I looked listed the use of a blowoff valve as controlling compressor surge, and a bypass valve doing the same thing. They're also called surge valves, hooter valves, shift valves, relief valves or dump valves. Straight from Greddy's website: "Our Blow Off Valves are easily adjustable to prevent both premature boost leakage and compressor surge." I think I'll believe what Greddy says more quickly than what you can say. No offense, you're usually a wealth of information, but they have a little more experience with turbos. Bob P.S. I'm up to 93 posts.
Posts: 1,428 |
Bob,
If you re-read my post above you'll see that both the blow-off valve and the bypass valve perform the same function, without being the same thing.
Blow-off valve vents the compressed air stack to atmosphere (out of the car's intake system). Good only on MAP sensored engines. Loud pschht sound.
Bypass valve is plumbed back into the system downstream of the MAF. That way air that has been metered is not lost. Imperative to use that on a MAF sensored engine. Mild pschht sound.
See? Demon is right, they are not the same item, but I have to add that they do perform the exact same function.
Posts: 104 |
Aaaaahhhhh. Now I get it. I had read your original post yesterday, but DemonSVT had said otherwise, and when I came back to review what else had been added to the post I didn't go back to see your first post, so it was kind of a one opinion against another opinion thing, with me forgetting a little, and reading too quickly to properly take in what people were saying.
Thanks for spelling it out for me Pascal. I think we were on different wavelengths because I was still thinking that the Bypass valve was for preventing compressor surge and the Blow Off Valve was for preventing overboost, as DemonSVT had said. So when you said that they both prevent compressor surge I took that as meaning they are the same thing, just set up to vent in different spots.
And Demon, sorry for saying you were wrong about them being different, when you were actually right. I didn't mean to really come out and yell YOURE WRONG, but I think it kind of came out that way in one of my posts.
Bob
A little knowledge is a dangerous thing.
Posts: 111 |
Originally posted by DemonSVT: Originally posted by rimmie: [b]Please don't bother to offer information or post if have nothing good to say at all. Bah humbug... :rolleyes:
What should I expect coming from you after all... Nothing new... :p [/b]WTF?? Thanks Demon, i'll be sure to send all my posts to you and have you proof read them before i send them through.  You truly are an a$$hole!! I never start flame wars, but you seem to love to work everyone's last nerve. I don't post here alot, but i do read alot of your posts everyday and you always seem to have the "foot in mouth syndrome". I think you have started more flame wars than any poster i have seen!! I would rather figure things out by myself than listen to knowledge from an arrogant person like yourself. Admin please feel free to close this thread at any time. I'm holding myself back the best i can. :rolleyes: rimmie
Posts: 443 |
Originally posted by Bob H: The bypass valves on Roots or Screw type superchargers are different than bypass valves on turbos. Roots bypass valves are used to increase fuel economy in normal driving (not under boost) by allowing the air to enter the engine without going through the supercharger, thereby eliminating alot of the power loss due to compressing the air. Since Roots type superchargers are generally installed after the TB, they don't have to worry about compressor surge.
DemonSVT, please correct me if I'm wrong, but I'm hoping to clarify what you're saying a little. The wastegate controls the boost a turbo makes by limiting the amount of exhaust that goes to the turbo, thereby limiting how quickly it can spin, thus limiting the boost it can produce. It is installed in the exhaust stream before the turbo. The wastegate also protects the turbo from spinning too quickly and destroying itself by limiting the amount of exhaust gases routed to the turbo.
The blowoff valve is a safety valve that is installed in the intake stream after the turbo compressor to protect your engine in the case that the wastegate malfunctions, or someone bumps your boost controller and accidentally sets your boost to 80psi instead of 8psi or something. It is a backup device for protecting your engine.
I know we're discussing conventional turbo's here, but a wastegate is not required if you use a variable nozzle turbine turbo, since it can control the boost by itself.
Bob Bob your theory as to the function of bypass[blow off] valves on roots superchargers is incorrect. The valve does exactaly the same job it does on a turbo system. The roots supercharger will cavitate when the throttle is slamed shut, by piping the pressurised air back to the intake side of the supercharger prevents this. It has nothing to do with gas mileage. When you shut the throttle on a turbo engine you need to either vent the unneeded pressure back to the intake of the turbo[maf system] or vent to atmosphere[map system] or your turbo will suffer compressor stall.
Posts: 443 |
[b]Blow-off valve vents the compressed air stack to atmosphere (out of the car's intake system). Good only on MAP sensored engines. Loud pschht sound.
See? Demon is right, they are not the same item, but I have to add that they do perform the exact same function.[/b] They are the same piece of hardware! The only difference is a piece of rubber hose,thats all. They are the same valve!
Posts: 104 |
Originally posted by RedSVT: [QUOTE]Bob your theory as to the function of bypass[blow off] valves on roots superchargers is incorrect. Sorry RedSVT I know I'm right about the bypass valve on roots type superchargers. This comes straight from Magnuson's (aftermarket dealer for Eaton Superchargers) : "The best kept secret in forced induction is the little known bypass valve. This small valve, when properly installed between the supercharger and the air throttle body, allows the supercharger to become extremely efficient in terms of economy and parasitic power loss. Our M90 supercharger uses less than 1/3 of 1 HP at 60 MPH cruising. The bypass is operated by a vacuum actuator control unit that is normally closed. When vacuum is high (idle-cruising) the actuator opens the bypass valve, equalizing the vacuum pressure throughout the system. When boost is required (accelerating) the vacuum is decreased and the bypass valve instantly closes, causing pressure to increase into the cylinders. This equalized vacuum condition virtually eliminates the normal parasitic power loss of a forced induction system." http://www.magnuson-products.com/bypass_valve.htm Bob
Posts: 443 |
Originally posted by Bob H: Originally posted by RedSVT: [b][QUOTE]Bob your theory as to the function of bypass[blow off] valves on roots superchargers is incorrect. Sorry RedSVT I know I'm right about the bypass valve on roots type superchargers. This comes straight from Magnuson's (aftermarket dealer for Eaton Superchargers) : "The best kept secret in forced induction is the little known bypass valve. This small valve, when properly installed between the supercharger and the air throttle body, allows the supercharger to become extremely efficient in terms of economy and parasitic power loss. Our M90 supercharger uses less than 1/3 of 1 HP at 60 MPH cruising. The bypass is operated by a vacuum actuator control unit that is normally closed. When vacuum is high (idle-cruising) the actuator opens the bypass valve, equalizing the vacuum pressure throughout the system. When boost is required (accelerating) the vacuum is decreased and the bypass valve instantly closes, causing pressure to increase into the cylinders. This equalized vacuum condition virtually eliminates the normal parasitic power loss of a forced induction system." http://www.magnuson-products.com/bypass_valve.htm
Bob[/b]I'm sorry Bob but you misunderstand the info! I have worked with Dave Magnuson myself a few times on different projects, in fact I own,use and install several of his products. The description of operation you posted is exactaly the same way a blow off or by pass valve works on a turbo system. If you dont believe me call them up your self and see!  Oh I almost forgot. Magnuson is the ONLY FACTORY EATON supercharger servicing facility in the US. Take a look at the blowers that B&M sell, they are Daves own design. He used to build them and sell them. He then sold the company and began his new buisness with EATON.
Posts: 104 |
Holy crap that was a fast reply. I was going back to edit my post to add that they may use the bypass valve for compressor surge, but the main benefit seems to be the economy, at least from Magnuson's marketing. I'm still not convinced (or maybe I should say I don't quite understand) that the Roots bypass valve does anything for compressor surge though. On the 4th gen Magnuson blower, the bypass is an air path from directly before the compressor vanes to directly after. The throttle body is located well before the compressor. My understanding is that compressor surge happens when a downstream TB slams shut and the compressor continues piling air up behind the TB. If the TB is located before the compressor, there is no wall to slam the air into. Now, whether the bypass is open or closed, the vanes are still going to be starved for air by the closed throttle body. Since any air that does not get sucked through the bypass and gets compressed by the blower has a relatively straight shot into the cylinders, there is no wall to create compressor surge. How does the bypass limit surge if there is nothing to cause the surge? I'm not trying to be a dick by disagreeing with you, I'm just trying to show you my thinking so that you know how to approach an explanation that will make me understand. You seem to have a lot of experience with magnuson blowers, so please fill me in. Hopefully this will make sense in the morning. Oh wait, I think I might have it. I may be looking at the airflow through the bypass backwards. I assumed that when the bypass was open, the air went right through there into the engine and completely avoided the compressors. What you're saying is that the bypass valve allows air that comes out of the compressor to be rerouted directly in front of the compressor again, so that it is not starved of air, and thus prevents cavitation (assuming that is what causes the cavitation. And exactly what do you mean by cavitation, since the only meaning I'm familiar with has to do with bubble formation in a liquid from rotating parts)? The way it was explained on Magnuson's and whipple's websites makes it sound like all the air goes through the bypass, and none through the compressor. Was that written by the marketers to try to dispel the myth of superchargers causing huge amounts of parasitic drag in normal cruising? Hopefully nothing in here sounds confrontational, I'm just trying to get this figured out. And get my posts up to 100. I think this thread might do it. Bob Edit: If roots bypass valves aren't there to help with fuel economy, please ask Magnuson to fix his website next time you talk to him, since his site clearly states otherwise.
Posts: 443 |
Bob
Edit: If roots bypass valves aren't there to help with fuel economy, please ask Magnuson to fix his website next time you talk to him, since his site clearly states otherwise. OK, I will make an attempt.[boy is this going to be long and drawn out]So bear with me. You are correct you were thinking the airflow went in the wrong direction, dont worry about it MOST people make the same mistake. Think about this for a minute. The supercharger is part of the air intake circuit,it lives between the throttle body and the intake valve. The bypass or blow off valve is in the circuit between the output of the blower and the intake valve. The only things that are generaly located between the throttle body and the intake of the blower are the EGR valve,vaccume takeoff points for such accesories as power brake booster, cruise controll and any other vaccume operated motors on the car and the connection for the bypass or blow off valve. Let me address the cavitation while you have this picture in your mind. A roots blower or a Vortech blower are driven by a belt that is turned by the crankshaft so as long as the engine is running the blower is pumping[of course the faster the engine runs the more the blower pumps]Now lets say you are accelerating, you reach the desired speed and let off the throttle. What happens? You create on huge vaccume drop in the section between the throttle body and the intake of the blower. This happens because the blower is still pumping by a great amount as long as the engine RPM is up. This is what causes cavitation, the rotors are still spining trying to pump air but they cannot because the supply of air[the throttle] has been closed. This is also refered to as dead heading a pump. Now this is where I will try to clear up another misunderstanding. The by pass or blow off valve will help in the MPG of the engine in this way. Keeping in mind the dead heading situation previously mentioned. There is a LARGE amount of vaccume on the inlet side of the blower and the blower is cavitating[because air supply is cut off by closed throttle] The output side of the blower[between the blower output and the intake valve] is HIGHLY pressurized, so the air is backed up and the blower is pumping against excess air. This puts alot of drag on the blower rotors and makes it hard for the crankshaft of the engine to turn the rotors. It is this parasitic drag that causes the engine to consume for fuel because this heavily loads the engine. The answer to both of these problems was to place a valve between the output of the blower and the intake valve and plumb it to the intake side of the blower between the throttle body and the blower intake. Now when you let off the throttle the bypass[blow off] valve opens and the excess air[pressure] flows to the intake side of the blower where it is recirculated through the blower[ending cavitation by supplying air to the intake side of the blower and releiving the dead heading situation by allowing the pressure to escape] and is finally consumed by the engine. This releives the parasitic drag on the engine and therefor helps the MPG because the blower is not dragging the engine down because it is dead headed. There are no untruth's on the Magnuson web site you just misunderstood what was meant and how it was acheived. The bypass[blow off] valve does the same thing in a turbo system in that it lets the backed up pressure escape to the intake side of the compressor on the turbo, same thing really! Boost is boost it doesnt matter if it comes from a turbo or a supercharger it is all the same thing. COMPRESSED AIR. The only difference is how it was compressed. By the way I didnt take any of your coments as confrontational. I think open discussion is good and should be done on a regular basis on this site so that more people can learn. Who knows what great things could be acheived if people would talk out there viewpoints rather than give smarta$$ed remarks and to ridicule someone for asking a question. I hope this helps, if not post more questions and we will try again.
