I just finished the SC install and I can not get the car to start. The motor turns over and seems to turn over for about 3 to 4 seconds then it acts like it is miss firing. Any suggestions would be appreciated. I have checked every electrical connection I can think of. Checked all vacumn lines and fuel lines eveything seems to be OK. Thanks for everyone help on this matter.
No fuel???
Bad chip burn.
Pull the chip and see if it starts. However DO NOTHING else! Like drive it or rev the engine.
2000 SVT #674 - Check it out!
I would have to say check all your hoses for your fuel system. See if there are any leaks? How much did you take the car apart? If you could take some pics of your setup.
Sam
1998 Contour SVT #180
1/4=14.2 @ 101.17MPH
AOL users = PhatSVT
_ _ _____________ _ _
1986 Mustang GT
12 second club
Did you triple check to make sure that contacts for the chip are clean? Sounds awfully like other times I have heard of people having their chip lose contact on the road.
Oh d@mn, I didnt realize Vortech put the chip in for you. Never mind ...... :rolleyes:
You're supposed to send in the ECU for Vortech to install and test the chip. If it ends up being that, I'll be shocked. It also voids that portion of the Vortech warranty, so make sure and call them before removing the seal they put on over the chip.
Make sure you hear the fuel pumps come up to pressure when you flip the key on, but not to start. Ensure you have spark by using a spare plug hooked to one of the plug wires and grounded on a metal engine part, crank it to see the spark.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
Have fuel, have spak. Will pull the chip from Superchip and see if that will let me get the car started. Thanks for all of your imput.
W
W
check the fuel pump wiring. when you turn on ignition you should hear the two pumps prime separately.
Also, check all of your grounds and connections from your battery relocation, if somethign is lose it can cause an immediate stall once the engine starts because of vibration.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
My Superchip never worked. I have a special chip burned by Vortech. It still isn't right, but I am returning to them Friday. I will keep you all posted about the results.
Jim
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
If you have fuel and spark, it's not the ECU working against you. The DIS will not fire without ECU approval as when as failed chip happens. Are you double sure you have the plug wires on correctly? Do you have an OBD-II scanner to check fuel line and tank pressure? Spark advance? Pending codes?
Brad Noon
'99 SE MTX
I hate to disagree with you bnoon, but my symptoms were exactly the same as his. And it was the chip.
Jim
