OK..so
this post got me thinking. What does it take to put a M90 or M62 Eaton blower on a tour?
Aside from hood clearance, what else does on need to get this to work.
On Magnuson's site they state "The proper location for the supercharger is between the air throttle body and the intake manifold."
So we could mount the SC on top of the engine, provide an inlet to the TB. The mounting on top of the engine is the trick. How? I think a new intake will be needed to mount it as well as to provide an outlet for the SC.
So..aside from hood, new intake, and some inlet tubes to the TB..is there anything else that is needed?
The reason I am bringing this up is to have another option to adding HP to the Tour. There is no way I am going to spend 5g's on a turbo. If I had 5g's I would sell the Tour and get something else. 3g's and reliabilty of the Vortech is still iffy. Maybe someone will sell one used for about 2 but you still have the reliablity issue. 1-2g's for a 3.0L..sounds a little better but HP is up but not substantial like a SC.
A Eaton M90 you can get from a T-bird for less than $500 (heck, i have seen them for 250, some with intercoolers) So..if you spend 500 on the sc and the rest on fabrication you still might come out ahead.
I am just talking out of my a$$ since I have no clue about fabrication costs or if this will really work. Again I just want to see if this is an idea to explore or to just forget about it.
Thanks.
