Posts: 3,636 |
Originally posted by unknown: No news is bad news... -------------------- 2k silver svt #1721 1. custom stereo 2. KKM induction kit 3. eibach springs 4. sho shop y 5. custom catback 6. more to come.. "Ignorance breeds stupidity.." Italics and bold added for emphasis. Truer words never written.
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 5,805 |
As I have said, anything from Demon Dynamics for the Zetec can be had from us,STILL and dispite the changes 'at the helm' of DD....TH
Posts: 1 |
I have a 98 Escort ZX2(80,000miles). I'd like to add a turbo to the car this winter Should I get a different engine or is this one ok? also could you email me some info on the turbo kits (price what they include and any other useful info,such as what each item does, would be helpful because I don't know much about turbos)
Thanks, Dave dave_ehlers@hotmail.com
Posts: 4,528 |
From what I understand installing a turbo on a high mileage engine is not a wise thing to do. If you have a problem and do not know of it the turbo will make it 10 times worse and motor will ultimately fail. Terry could answer better than I though.
Administrator
Administrator
Posts: 5,037 |
A ZX2 with that many miles would benefit from Terry's higher stage kits that get a block rebuild. You get a turbo AND a refreshed block at the same time!
Posts: 2,143 |
Or you can do like me and have Terry rebuild your Zetec and replace like everything, and then install the TURBO!!!!!
Im goin to be flying when its all said and done!! I cant wait!
'95 Tour LX ZETEC MTX TOO MANY MODS TO LIST ANYMORE!! http://www.geocities.com/marine113 Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
Posts: 102 |
This whole thing sounds like it going along pretty well!!  The one thing I was wondering "And mabybe I missed it" Do you "Chris,Terry,and Street Fighter" Plan to use a copper head gasket with this set up. With even the stock compresion being high I can only imagine the compresion of 2.5 durtech with a 10 Psi Turbo??????
1998.5 CSVT K&N Custom Intake Custom 2 3/4" Magnaflow cat back Ram HD Power Grip Clutch Bosch Platnium +
Alpine deck "CDA-7863" Boston mids
More to come
Stock Sucks!!!!
Posts: 7,329 |
Originally posted by TommyBoy: This whole thing sounds like it going along pretty well!! The one thing I was wondering "And mabybe I missed it" Do you "Chris,Terry,and Street Fighter" Plan to use a copper head gasket with this set up. With even the stock compresion being high I can only imagine the compresion of 2.5 durtech with a 10 Psi Turbo??????What's wrong with runing a turbo at 10psi on engine with 9.7-10.25CR? They do seem to hold up fine to the S/C (only if the s/c did) BTW - the turbo will be intercooled It should be easier on the engine by forcing in cooler air. Also PSI level means very little. It's the cfm flow that get's you!
Posts: 102 |
Well Demon I am pretty sure i heard people say that they did have problems with the head gaskets in the Super charger applications, No to metion this is a valid quetion, no need for you normal critassim
More to come
Stock Sucks!!!!
Administrator
Administrator
Posts: 5,037 |
Head gaskets are fine. 9PSI with no intercooler on the Vortech kit doesn't blow them. Some engines are more prone to head gasket failures. *cough* NEON! *cough*
