#405885 12/26/01 10:18 PM
Came across this the other day which may help acessing your engines CR (simulated) under various boost levels.
Final Comp ratio= [(boost DIVIDE by 14.7)+ 1] X existing CR.........
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#405886 12/26/01 10:28 PM
Hmm that means roughly 14.5:1 on the 3L S/C with 9 lbs boost. Sheesh, that's gonna be hard on things. At least I don't plan on this motor lasting forever! Hopefully the trans will, right Terry? laugh
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#405887 12/26/01 10:38 PM
If you start with a lower cr more of the engine range is in a 'progressive' boost above atmospheric.Once you are over around 10:1 on say a 91 octane at stoichometric a/f ratio (14.7) you need enrichment to go higher re det etc......
V6 MTX
#405888 12/26/01 10:42 PM
W
W
so if I did this right under 10psi boost I have 16.8:1 C/O?
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
#405889 12/27/01 01:39 PM
With a 10:1 Cr on the motor yes @ 10 psi it will be 16.8:1 CR, hence the need for ign retard /enrichment and H20 to reduce det...but then again no one ever works out the 'stoc' cr correctly (ie the intake valve is still open as the piston accends on compression so the swept volume is less!!!!)
V6 MTX
#405890 12/28/01 10:45 PM
I
I
That's right Terry, completely forgot about that. Thx!
That's another nice input for perfecting my calculations...
Need to look up those valve timings....
You wouldn't happen to know them for the 1.8 Mondy, would you?
Further if it has any interest, I have (and am still) looking into turboing my 1.8 Zetec (115hp, CR10:1).
A Mondy fellow overhere is running with 200hp@4800rpm, only with a Fuel Pressure Regulator, otherwise stock.
Above 200hp@4800 the A/F ratio leans out.
The guy is still working to improve it further..
AFAIK these cars do work with high CR turbo:
The Focus 2.0 has a 9.6:1 with some 8-10psi boost (Aerocharger)
The Audi TT 1.8L, 180hp has 9.6:1 and a 11.8 psi boost....
It should be possible.
'97 mkII 1.8 sedan, mtx, Diamond White, Magnecor KV85, clear side repeaters
