#405108 08/05/02 03:36 AM
O
O
Okay I have a chance to pick up some svt cams. In your honest opinion do you think it would be worth it? How much would u pay for cams with 30k miles on them. Just not sure what to do here. It doesn't seem like svt cams are all that much agresive. Any input please.
#405109 08/05/02 04:59 AM
1
1
Get them anyway. Pay maybe $300 for all four, then put them on. What you gotta loose since you're spending probably $4-5k on the 3L anyway.
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#405110 08/05/02 05:04 AM
Personally I would choose the SVT cams over any other cam set. Real life or fictional/custom.
I've done countless tests and configs with different cam specs and SVT really nailed the profiles to a tee. The only thing that always shows up in my testing is that the exhaust cams duration could be raised ~5-6 degrees.
Personally I think that is because the stock 26mm valves are ridiculously small!
Change out the valve specs to match the 35mm/32mm 3L valves and the "optimum" cam specs are within +/- 2 degrees of the stock SVT cams.
With the ~10.8-11.2 compression 3L hybrid the cam specs are dead on perfect!
You lose far too much power curve below 5500rpm to lengthen the intake cam's duration. You may gain a handful of peak power (~5-8HP) from 6-8k rpm, but your powerband below 5500rpm suffers significantly...
BTW - those thinking about increasing the lift (grinding the journals, new cams, etc)
Increasing the lift 10-15% (possible piston knockers) produced a max of only 5 HP at the crank. All peak - 5500 & above.
Stock SVT cams & 3L valves for me thank you... laugh
2000 SVT #674 - Check it out!
