Posts: 145 |
I'm about to get a 02' Duratec Taurus. Will this engine benefit from the DMD or are the harmonic frequencies it eliminates specific to the 2.5?
Nick Johnson nick@nejohnson.com 97' Contour Sport-Blackie 96' Contour SE -Wife's Car 87' Thunderbird TC - Retired (for now)
Posts: 3,419 |
FWIW, I have one on mine. Dunno if the lower redline on the "Taurotec" PCM makes much difference.
Posts: 3,248 |
I have not confirmed this but supposedly the 3L (duratec based) Mazda 6 gets the DMD. The bottom end is very similar as well.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,562 |
The Duratec in the Contour has a different FEAD location (Front End Accessory Drive if I remember the letters right), therefore could not be used on the Taurus to run the factory Taurus pully/belt driven accessories. You'd have to find another 3 liter or 2.5 liter with the correct FEAD set up to snag one from.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 5,805 |
....but it's on the ST220...which is 3.0...
Posts: 3,562 |
Originally posted by Terry Haines: ....but it's on the ST220...which is 3.0... With the same Taurus FEAD??? Because he's looking for it to fit a 2002 Duratec Taurus, not a Contour swap situation. If so, then hurray for the Tort-i.
Posts: 5,805 |
No the ST220 does not use the 3.0 Taurus FEAD but it would be a simple m/c shop job to make up a bolt on extension pully,as the Taurus 'outer' is,picking up on the 3 X 8mm puller holes on the hub.The stoc Taurus damper has an internal l/h thread to which the extension pully screws into...
Posts: 3,562 |
There you go Nick, Terry's your man it sounds like! Go Terry Go!!!
Posts: 81 |
Your other option would be to wait until the 2003 Taurus 3.0L comes out and pull one off an engine. My sources indicate that it will have the DMD. And no, it's not the same as the Mondeo DMD.
Posts: 52 |
Originally posted by Procyon: From just the bare engine perspective (long block), the 3.0L also carries over into 2002 unchanged for the Taurus and Escape. New for 2002 is the 3.0L Mondeo ST220. if the '02 Taurus Duratec is no different from the the '98-'01 Taurus Duratec, then are you saying the DMD is not a direct replacement for any Taurus Duratec?
1999 Cougar V6 MTX Newbie, but learning...
