Originally posted by bnoon:
Cam retainer bolts. They're torque to yeild and snap off very, very easy. Hard bolt and soft metal head castings makes it a bit harder to drill it out and re-tap too.
Water crossover tube gasket ring. It's just a small rubber O-ring, but worth replacing because it can cause a major coolant leak if you rip the old brittle one.
Brad, I was on the phone with Bill today placing an order. I told him about getting the cam retainer bolt, and he said he's not sure which one I'm refering to. The same thing goes to the water crossover tube gasket ring... Can you give me more insight on those two items?
