#404693 05/23/02 01:43 PM
BIG JAY Offline OP
ok I will be getting a motor (2001 3.0) with 10,000 miles for $550. I am happy about that price. I will be getting the headers also. What I need is a parts list on what to swap over an keep. I will be swaping the heads,values and block. I will use the 2.5 UIM,LIM and cams. witch injectors should I use and what mods have to be made to do the swap with the motor and the headers to fit the 3.0 beast
:p
98csvt(red)white 19''Axis se7ens on toyo 225/35/19's injen intake,cust exhaust, High Rev's racing clutch,and flywheel .whatever its takes to run 12's (system)Eclipse 5442,Boston 6 1/2" pros, Eclipse 5x7 point scourse,PPIpc4400,PPIpc2600(chrome),power cap,2 12"JLW6
YOU WILL RESPECT THE FAMILY CAR
W
W
Your post is unclear. You are using a '01 block and are swapping the heads and valves over? So I take it you are going to run the 2.5L heads with the 3L valves in them right?
IMHO that is a great combination and the heads should bolt right up to the 3L block. Make sure to prep the heads a little bit. Above all, read through the old posts in this forum as I did almost the same route, but I am too tired to rewrite everything again. You should find what you are looking for with the search routine. Most of us have detailed all the important points in these previous threads. IF after reading all that it isn't clear, then as us some questions and you will find MANY helpful answers are out there.
Good luck.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
