Here is a repost of what I wrote in the other thread.
I hope you guys realize this is an OLD post!
I used the SVT cams because of the waterpump drive. I just went through the cams with a micrometer and a lot of pencil drawings trying to decide whether or not I could 'visually' see a difference between 8 degrees or not.
In another post after tossing it around about the percent error, we agreed that 'visual' differences may have been so slight as to not be noticeable. Therefore there was no real basis to think that the cams are the same. So I backed off and agreed that I was MISTAKEN. I had no real way to verify that the cams are different or the same.
Hope I didn't cause anyone to be confused.
I have no Idea why this post keeps getting linked to from other areas as there is no benefit to this discussion.
(PROCYON, can you explain that? If you are pissed off because I doubted the specs, then get over it man! I backed off as I said, but I still remain neutral on the subject as I have nothing to argue the point. It was nothing personal.)
What am I the only one on this forum who has the guts to be wrong sometimes AND admit it too?
If people don't challenge old ideas then new ideas would never be created. The world would still be flat!! I say it takes an inquisitive mind to challenge something, an educated mind to make a good showing, and a MAN to admit when you are wrong!
warmonger
