Q
QWICSVT Offline OP
Q
Hey all,
Would anyone know how to defeat the PATS system in order to transplant an SVT engine/SVT engine comp into a pre 98? I have done all my work with post 98's till' this point so I am a bit in this dark on this particular issue.
Matt
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound
Administrator www.fordcontour.org
Their was a guy that posted a question a couple weeks ago about upper intakes on the SVT engine he installed in his Mk1 Tour. Their must be a way if what he says is true.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
PATS - Passive Anti Theft System confused
If swapping puters, you would have a problem, why not just custom burn a chip instead?
There are ways around it, remote starts can be added to vehicles with this feature by using a module that imitates the key.
How to bypass it with out the proper lock cylander or the right key to go with that is beyond me, but it can be done.
W
W
You can re-program new keys to the PATS. The first two keys must be done at the dealer, but the dealer can also change the first two keys. From then on you can reprogram extra keys at will.
My advice would be to take the wiring that the pats system uses and have the dealer program two new keys. Or, get the old key and lock cylinder and just swap them in.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
