Master P
Master P
Posts: 5,455 |
Originally posted by warmonger: What is David going to do since he is selling his engine? David, where are you?
warmonger http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=50;t=000116
Posts: 4,528 |
jjennings looks like you've got a lot of work ahead of you. Going from the Zetec to 3.0L!
Posts: 154 |
Naw, I got rid of the Zetec cougar, it kinda fell apart.
2001 Mercury Cougar Aerogear WideBody Kit, Aerogear Carbon Fiber Hood 3.0 Hybrid 251hp and 229tq at the front wheels Eibach springs, Koni Stuts, Aussie Bar, ST200 R Strut bar, OMP front Strut bar, 19" RPM's 235/35-19 Nitto 555's All Alpine System - IVA-C801, DHA-s680, NVE-N852A, TCS-V430A, TMX-R705, TME-M580 x2, PXA-H900, MRD-M500 x2, MRV-f540 x2, SPS-0829, SPX-F17t, SPX-17m x2, SWR-1021D x4, RUX-4280 http://www.geocities.com/socal_neco/jimmy.htm
Posts: 180 |
I'll be interested in seeing DavidZ's engine dyno in a different car.
Mark Wilson
98.5 SVT Contour 93 SVT Cobra #1824 93 SVT Cobra R #84 1972 Mustang Convertible 1970 Mustang Mach 1 1967 Sunbeam Tiger
ALL MODIFIED!!
Posts: 3,636 |
Bringing this back to the top.
Has anyone heard any news on this project.
I know, search the other site, right?
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 4,042 |
I peeked 'over there', and the motor is in the car and running, along w/ the 3.0 upper. Hmm, 3.0, 2.5 heads, (high CR, small valves) 2.5L LIM and 3.0 UIM, then quasi-dual exhaust. Let the motor breathe, then choke it down, then let it breathe again, then choke it down again w/ the quasi-dual exhaust? Why? Congrats on the project and that it's running though.... John
Posts: 460 |
Good call Jugs....but you know that what they are doing is the only way to do it right? No sense in offering advice or even common engine building sense..... Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 7,329 |
Originally posted by chezterr: but you know that what they are doing is the only way to do it right? No sense in offering advice or even common engine building sense.....
Nikolas touche'
Posts: 277 |
You are correct in that the car is running but you were wrong on the car being "choked". Just the opposite in fact, the car has... 1.) a 1999 3L short block 2.) ported and polished SVT high-comp heads 3.) the valves flow just as much as larger valves do as the opening that the valves "seat" in is the same where the valves are larger or smaller, only so much air can flow through the same sized hole 4.) the LIM is a 3L piece with some custom mods to make everything work 5.) the UIM is also a 3L piece with improved airflow characteristics 6.) the secondaries are fully functionaly thanks to a customed designed IMRC 7.) a custom manufactured intake has been installed an now occupies the area where the battery used to reside 8.) gutted pre-cats 9.) the engine ran incredibly well with the stock Y-pipe and exhaust but... 10.) this week it receives a fully custom Y-pipe and cardoc exhaust system design especially for this particular vehicle 11.) and maybe the biggest part of the whole set-up, 24-lb injectors that finally gives this engine the fuel it needs
The car runs very, very strong and already has all the ricers and turbo junkies in the area shaking when it pulls up to a stop-light. I can't wait to put it back into my garage in the next couple of weeks, as its been under construction since Jan. 2ond.
I look forward to posting a complete wrap up and numerous pics on fordcontour.org upon completion of the project, but until then, I am too busy attemtping to finish the beast and more importantly trying to find a JOB and plan a WEDDING, both of which take precidence over all else.
And finally, a quick word of good luck to all the other 3L and forced-induction Contours and Cougars in the works. It is truly an exciting time for these platforms!
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 3,419 |
One question: What are you going to use to control the bigger injectors and properly attain an air/fuel ratio that will produce max power? I only ask because I have seen Cardoc say he doesn't like the S-AFC. I can guarantee that the stock PCM won't do it and will throw rich CELs within a few days. Been there, done that.
Custom chip is the best way to go IMHO. "Ford 80 mm MAF calibrated for 24# injectors" is not a valid answer.
