Posts: 34 |
Hey guys, I see you are looking for 24lbers so here is a good thread that will help you find some return style 24's. I read it awile ago and thought you guys would like it. You can get them out of a 460 F-series,Cobra(93-98),and many more...look to find out...hope this helps!! 24lb injector\'s......
93 Mustang GT AOD-> T-5 swap 3.27's,PRO 5.0 shifter,BBK CAI,ASP pulleys,MAC 1 5/8 shorties,ProChamber,and catback AOD time.. 14.907@94 w/only pullies and drop in K&N NEW BEST: 13.83@100.56 with 2.11 60 ft
89 Probe GL 2.2 5spd AI and 130,000miles BEST TIME: 16.18@83.56
Posts: 3,419 |
And then you can go HERE to find out what cars come with the 80mm MAF stock. Nice find.
Posts: 1,022 |
Thanks dave, Always helps to get more info, thanks for the find. keep me posted on anything you find.
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 460 |
I went to look there.....just a few questions...
I have a list of OEM part numbers for return style fuel injectors.....
can someone put a list together of returnless injectors that has the OEM part number, the flow rating, and the cars they come in? that woudl really help us out. And then place it in the FAQ section of CEG....
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 34 |
It is possible to use return style injectors with non-return car. You will have to solder wires or put connectors on the injectors to make a adapter harness but I have read that this will work. Actually, Vortech has fuel injector adapter harnesses that are included with there Mustang SC kits so they can probably be purchased seperate to..just some thoughts. Not really that many returnless style injectors that you cna swap out.
