You know, just to be safe, I am going to buy a set of wires as well. I already swapped the coil packs out but no luck.
All of the theories I have postulated to date have been proven wrong, so I am not sure that this latest one about turbulence will hold up either. I hope I am wrong due to the cost, but it still sucks to do so much work/analysis and be wrong. Oh well, it wouldn't be the first time and wont be the last!
EDIT***************
I just want to update this the final time and let you know that the whole turbulence theory is out!
I replaced my plug wires and have found that the stuttering is gone. Don't ask me why there is an rpm dependence and an airflow dependence on the spark, it has eluded me. Lets just say that if a contour V6 is stuttering then its time to check/change the plug wires.
As far as the coil packs, they were not an issue for me, so if I were you guys I would keep and test your old ones to make sure and see if it truly is only the plug wires. I tested my coils hot and cold, and the resistance changed from 13Kohms cold to 16Kohms very hot. With the new plug wires there is no issue even hot, so the coil pack is eliminated in my case. BlackPantherSVT, try your old coil with the new wires and see if it still runs ok.
I ask this as a final test so we can narrow down the issue for other CEG members and save them from spending extra money. Once we know for sure then we can have Lance Kinley add it to the archives as a solution. As of now, my advice is to change wires first since they are only $50 for a set, whereas the coils are bound to be more.
Thanks again all for the diligence in tracking this down. I guess that is a close since I am the last to verify that the symptoms are gone.
END EDIT*************
warmonger
