Posts: 249 |
Does the water pump on the 3.0 Duratec in the Taurus use a metal or plastic impeller on the water pump? I am looking at a 2000 model. It seems that a more than a few have had failures with their 2.5 water pump with the plastic impeller.
Administrator
Administrator
Posts: 5,037 |
2001 (I think) is when they started putting the waterpump on the correct side. I would think they are using the updated white plastic impeller. Brad?
-Chris
Posts: 5,805 |
I'll tell you next week when a new 3.0 Taurus motor arrives at HMS Inc for............nah,not yet....or even the 'second hand' 3.0 we have for....nah, cant say !...but I'll take a look at the pumps......
Posts: 3,562 |
Exciting times are brewing. I can't stand all of this secret keeping that's going on. For the betterment of the group, all of my projects are put out for all the world to see... Probably because I like to show things off a bit... (Frustration sets in) :p Chris, until the complete motor assemblies of the '01+ 3 liters comes down a bit, I'll still be pushing the older 3oh with an electric pump for at or near the same money. Hence, no pump for me to look at.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 5,805 |
Brad ,a good used 2000+ motor can be had for around $800...!!!!!!!,new is around $2000
Posts: 351 |
Does the 2000+ have return or returnless fuel system?
98 Contour LX V6 Mtx
Posts: 7,329 |
Originally posted by IndyTour: Does the 2000+ have return or returnless fuel system? Doesn't matter. You will be using your original fuel management equipment. Unless of course it was just a curiosity question...
Posts: 3,562 |
Originally posted by Terry Haines: Brad ,a good used 2000+ motor can be had for around $800...!!!!!!!,new is around $2000 I know, and I can get '00 or older complete used 3 liter engines for more than $300 less delivered to cover the cost of the electric water pump. Same price = more HP going with an older block. That's what I was saying!
Posts: 539 |
If you use the 3L heads u can't use the stock fuel managment system on an E0. And on the 01' engines the waterpump is run off the camshaft same as the 2.5s.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
Posts: 54 |
If you use the 3L heads u can't use the stock fuel managment system on an E0. Why is that?
'99 Cougar V6 5spd - I/H/E, Koni/GC
