Posts: 1,445 |
stupid question time:which 3.0 are u all using? the sho 3.0 or the regular run of the mill duratec??? the sho of course has gobs of horsepower but the duratec in my mothers 2000 taurus is a puny 140-145 hp v6 and i know the other duratecs are about the same...
if using the regular duratec what are you guys getting for hp after install and/or what are u doin to make this a higher output engine???
i need to know so that i can save an pray and save and sell my body to get the money for the conversion for my v6 se
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 1,090 |
It sounds like your mother's car is a Vulcan motor, rather than a Duratec. As for the SHO motor, it will not fit. The higher output, 99 and up Duratec motor is the upgrade motor. Look for the Taurus with the 3.0, 24V, 200 hp motor.
Posts: 5,805 |
Taurus 3.0 Duratec or LS 3.0 Duratec or,due in 2002 X type Jag 3.0 Duratec....
Posts: 583 |
Originally posted by Terry Haines: Taurus 3.0 Duratec or LS 3.0 Duratec or,due in 2002 X type Jag 3.0 Duratec.... Terry do you know for sure that the Jags 3.0 will fit? If you do then I will wait.. Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 5,805 |
The X Type Jag is 75% LS re Engine.The 3.0 LS blocks are shipped to UK to have 'Jag' heads,cams,intake manifold etc...this gives them the higher output Vs LS engine but the 'short block' assy is the same...I think the biggest prob is getting the total Jag engine...need to be on a 'waiting list' for a totalled wreck......
Posts: 1,445 |
thanks guys cleared that right up for me as i didn't even realize that ford still made the vulcan motor....
okay next question: will the 3.0 fit to my auto tranny or will that take mods???
thanks for all the great info on this site
Posts: 1,050 |
I just saw a jaguar LS 3.0 on the streets of Tucson Today. I suppose the 2002's released in Sept or October anyway, at least thats how it has worked when I worked at the dealership.
what is the HP rating of the Jag X-type, and what indicates that it will have a higher HP rating?
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 51 |
well warmonger, I believe motor trend's numbers on the 3.0 were 231 hp, correct me if i'm wrong, but it should be quite a bit nice than the original 200. sigh too bad I have a zetec. Any one wanna give me money for a turbo???
Derek Johnson 96 Contour Sport MTX zetec with diablo chip, air intake "Help!! Someone stole my ding guards!!!hehehehe"
Posts: 206 |
Originally posted by Terry Haines: The X Type Jag is 75% LS re Engine.The 3.0 LS blocks are shipped to UK to have 'Jag' heads,cams,intake manifold etc...this gives them the higher output Vs LS engine but the 'short block' assy is the same...I think the biggest prob is getting the total Jag engine...need to be on a 'waiting list' for a totalled wreck...... Terry, what about the S-type engine? It seems to be the same base engine but with an extra 10 HP AND extra 10 ft-lbs torque. Is either engine available new out of the crate at anything approaching an acceptable price? Eric
Posts: 30 |
Is the Sable interchangable with the Taurus?
