Posts: 251 |
I'm starting to feel a little overwhelmed by this task that I have taken on. Things don't seem to be as straight forward as I had thought. I had planned on replacing my exhaust headers with the MSDS setup but now I understand that they are not a straight bolt on but require some modification. I can't seem to find a repitable shop that can replace my differential with the Quaife and repair what ever is causing my transmission to leak. On top of that, I'm still a little apprehensive about filling and blocking these packages on the new block.
This project is making me very nervous because if I mess it up, that's it. I guess I just need some words of encouragement.
Curtis Dead 98 Black SVT 92K
Posts: 1,090 |
Originally posted by SVTNupe: I'm starting to feel a little overwhelmed by this task that I have taken on. Things don't seem to be as straight forward as I had thought. I had planned on replacing my exhaust headers with the MSDS setup but now I understand that they are not a straight bolt on but require some modification. I can't seem to find a repitable shop that can replace my differential with the Quaife and repair what ever is causing my transmission to leak. On top of that, I'm still a little apprehensive about filling and blocking these packages on the new block.
This project is making me very nervous because if I mess it up, that's it. I guess I just need some words of encouragement. Send your block and trans to Brad Noon with a little bit of money!
Posts: 1,225 |
No offense to you or anything, but if you are this unsure about the project you need to take some classes or find someone else to do it. Swapping an engine is not for the faint of heart nor is it for someone that has absolutely no experience doing so. This is not to say it can't be done, but I would highly recommend that you look up your local community college or tech institute and take some basic mechanics courses at the VERY LEAST if you have no background in the automotive industry.
Don't feel bad that you may not know either, I sure as hell don't know enough yet to take something like that on. It really is a lot of work, no matter what the experienced guys tell you, it is complicated. They just have a lot background in engine building so it may be a cake walk for them.
I am in no way discouraging you here at all, instead I am encouraging you to research and learn as much as you can before playing around with your car. Knowledge is power and if you are this unsure about what is going on with your engine you don't have enough knowledge about engine building yet. I would suggest you take your time and be patient. Do some more research, take some classes, and do this swap right.
Ryan
Latest Mod: Mirko Splitter
Posts: 5,805 |
I/We,HMS Inc,have offered seminars on *MTX75 Trans*Duratec Engine*Zetec Engine*Suspension,Brakes & Steering* as our only two students on the MTX can testify,they now know how to strip an MTX and install a Quaife,the same can be said of a Duratec..We will also fit your Quaife if you are interesed in shipping the trans...PM me ,Regards Terry Haines,HMS Inc
Posts: 1,225 |
Originally posted by Terry Haines: I/We,HMS Inc,have offered seminars on *MTX75 Trans*Duratec Engine*Zetec Engine*Suspension,Brakes & Steering* as our only two students on the MTX can testify,they now know how to strip an MTX and install a Quaife,the same can be said of a Duratec..We will also fit your Quaife if you are interesed in shipping the trans...PM me ,Regards Terry Haines,HMS Inc  I'm one of Terry's students and trust me, it was worth every last penny.
Ryan
Posts: 251 |
Folks,
I'm not ready to give up yet. The tech manuals just aren't as detailed as I would have hoped. Hopefully, with the knowledge this group has, I'll be able to successfully swap my engine. I have no choice but to do it and I am quite a ways in to it. I have a couple of motor heads in my corner so I'm not completely alone in this project.
Posts: 17 |
99 Mystique LS ATX 40,000mi
3L Coming...Maybe. Owned for 6 Weeks.
Posts: 3,584 |
Good luck SVTNupe  With all the great people here in the CEG I know you'll get all the "correct" help you need, right guys
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 3,419 |
This must be a mandatory step in doing the 3.0. I was paying someone to do it and I even told myself that I should have just bought a junkyard engine at one point. It is overwheming because there is always "something small" that pops up (modular? hah!), but trust me, you will be fired up when it hits the road. Hang in there.
Posts: 669 |
'99 SVT Contour 1298 of 2760
