Also check the alignment, especially if the car has ever been hit. Alignment should not be done until the condition of the suspension has been checked, as Terry mentioned. Too much positive camber on that wheel can cause such a wear pattern. Less likely, but still a posibility is that the toe is toed in too much. With toe it is most likely to exhibit a wear pattern of both front tires equally, but not always. Also the other tire might actually be starting to wear that way but is just not as pronounced yet.
