Posts: 26 |
I guess that Im going to have to get a superchip again to rewrite the prom. since the computer falls back to a stored set of values, when at WOT. I m just worried about fuel delivery, since my car tends to run lean as it is.
Posts: 52 |
i was thinking of this route to 3.0 nirvana. since the escape is automatic and uses the CD4E, an ATX should be able to use the ECU/ECM/PCM without modification, right? i mean, since the tranny is the same (right?) and the inputs to the engine are the same (right?)... and of course, there's that kenne bell supercharger for the 3.0
1999 Cougar V6 MTX Newbie, but learning...
Posts: 2,794 |
Originally posted by Ricci Hull: Using a Taurus PCM would be a bad idea. Since they only came in auto, it will probably give you a CEL, if it even runs. APEX or the EEC tuner would be a better idea. That is incorrect, it can be pinned to run properly just check out the diagram...
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 5,805 |
FWIW using the 2.5 PCM = lean mix,using the lean mix with 2.5 heads @ around 11: 1 CR = det problems....
Posts: 3,419 |
Originally posted by Terry Haines: FWIW using the 2.5 PCM = lean mix,using the lean mix with 2.5 heads @ around 11: 1 CR = det problems.... yup, one day soon I'll be allowed to run at WOT
Posts: 251 |
Does anyone know if the MSDS exhaust headers will mate, without modification, to the '01 3L heads???
Curtis Dead 98 Black SVT 92K
Posts: 26 |
So is the consensus to go with the super afc for fuel delivery? How is everyone going about tuning this? Is it better to go with a dyno, or tune by driving. Since I am a tech at ford I have access to many usefull tools. I am very familiar with an NGS star tester, and WDS. These are both very helpful diagnostic tools, but unsure if helpful when tuning. Any experienced advice would be greatly appreciated. Id like to start gathering materials soon.
Posts: 2,794 |
The SAFC is a fuggin bandaid here. It does not cure the problem, fuel is not the only issue here. Spark needs are different between the two engines, the SAFC might work : BUT IT IS NOT RIGHT. ya just do not listen do ya?
