Posts: 97 |
I'm a rookie at cars and ive been having trouble with my car. I need to clean the throttle body, thing is, I have no idea what it looks like and i have no idea where it is..Can U guys help me out plese
I have a 1996 COntour with Zetec Engine.
Thanks alot
Dion
1996 Ford Contour GL K&N FilterCharger Changed most interior lights to blue Installed Xenons in high/low beams GTS Blackout Headlight Covers FLOWMASTER Series 3 NGK Sparkplugs WindowShield Washer Lights No Rez Custom Intake Clifford Sabre 2 Alarm System Removed Ding Guards
Posts: 1,444 |
how r u liking your sparkplugs.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 97 |
I love them, the idle is soooooo smooth
Posts: 54 |
The throttle body is attached to that accordian hose that goes to your air filter. Detach that hose from the throttle body, open the butterfly valve and spray all in there with some air-intake cleaner. You might want to use the whole can. Then reattach the hose, start the car and go drive it.
1995 Contour SE ATX KKM Intake TH fix Superchip Super high-flow pre-cats
Posts: 97 |
Thank you very much, Im gonna go try that right now
Posts: 708 |
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=6&t=003452 Just anouther thread about cleaning the TB. Thought it could be useful. I'm doing mine this weekend.
Ryan French
98 Mystique Duratec Sport(KKM, Custom Exhaust, debadged/dedinged, Tinted, A4 sidemarkers(clear), Bodycolor grill...Suspension is next.)
00 ZX3 Zetec Limited Edition(nothing)
Posts: 4 |
Be careful with throttle body cleaners. Make sure they are compatible with OX sensors and your cats. And even if they are, expect to receive a "Check Engine" warning message light up on your instrument cluster. If this happens, remove the positive battery cable for a few hours, then reinstall it. Turn off all electrical items (radio, blower moter, etc.). Let the engine find a stable idle, then let it remain there for at least 1 minute. Then turn on the A/C and let it stay on for 1 minute. Now go out and drive the car for about 10 minutes.
Use the throttle body sparingly. You can use gasoline or the throttle body cleaner on a rag to clean the interior surfaces of the throttle body which mate to the butterfly valve.
I have found the OX and cat sensors to be pretty sensitive on my car.
Paul V. 2000 Black SVT Bone Stock [email]null[/email]
