gmeeks Offline OP
I have a '95 V6 and cannot find the connector to pull codes? I've looked both driver and psgr sides on firewall, but can't find it? Would it be hanging loose or plugged into something?
'96 LX / No mods
2
2
It is in the extreme left rear (driver side) corner behind the strut tower. That is, if the dealer put it back in the holes, they usually drop it after they replace the cover. Black plastic "house" shaped connector. The small one is for the ABS if you have it. All the later versions have the connector under the steering column.
