Originally posted by 2112:
I work in Reston so keep me posted about Friday. Modded TB on sat. removed top 1/2 od the bar holding the butterfly. Bwahhh but now she feels a bit lean. Any thoughts.
2112- Are you certain that everything is connected up correctly? Air flow sensor reads what is coming into the intake? I would think that this would cause a check engine light tho. I once had the intake bellows off the throttle and did not secure it correctly and the car ran like crap too.
The only other thing is that since you have mods like exhaust to go along with your free'r flowing TB, you just might be a little starved for fuel. An adjustable fuel pressure regulator is probably needed.
