Posts: 1,795 |
The cd4e seems to be a pretty durable setup, of course it could be outside the trans that's the problem? There seem to be a lot less ATX failures than MTX failures  of course that could have to do with the ammount of power most of us are putting down
Every time I come online I wonder if the forums will be up
Posts: 1 |
Hi Guys,This is my first post on this site.I have a 99 atx cougar that ran a 14.3@98mph at Moroso down here in Florida.So its possible to acheive these numbers.I ran a 50 shot for about a year then upgraded to a 100 shot thats when I blew out both motor and tranny mounts the flex while revving the engine was incredible.I'M surprised I didn't loose the engine.No aftermarket companies made stronger motor or tranny mounts for the atx so I brought the car to the dealer and paid dearly!I removed N.O.S and sold it.The saying "its not a matter of will something break using N.O.S but rather when is so true"(but it was so fun)Thanks,Ron
Posts: 3,950 |
Originally posted by RonMorisseau: Hi Guys,This is my first post on this site.I have a 99 atx cougar that ran a 14.3@98mph at Moroso down here in Florida.So its possible to acheive these numbers.I ran a 50 shot for about a year then upgraded to a 100 shot thats when I blew out both motor and tranny mounts the flex while revving the engine was incredible.I'M surprised I didn't loose the engine.No aftermarket companies made stronger motor or tranny mounts for the atx so I brought the car to the dealer and paid dearly!I removed N.O.S and sold it.The saying "its not a matter of will something break using N.O.S but rather when is so true"(but it was so fun)Thanks,Ron  I wouldn't run anything higher than a 50 shot anyway.
Posts: 47 |
I Blew 2 Duratec's on a 100 shot of NOS (a Standard 2.5, and a SVT preped 2.5)
Now, I'm runnin a 3.0L and I'm thinkin of NOS again...
BTW Have you guys seen the article in SCC with a Turboed Matrix runnin 7psi on an engine w/ 11.5:1 compression ratio!!!! The key is proper fuel/engine management...
98 Contour SE Sport ATX lightly modded... =0) 14.1 @ 98MPH 1/4 mile!!! New Version 3.0 inside =0)
Posts: 724 |
I smell detonation in someones future....
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 3,950 |
Originally posted by SeR Guy: I smell detonation in someones future.... Talk about jinxing somebody.
Posts: 217 |
i put down 140.3hp and 138.4 tq. in my atx 95 se. only kkm and exhaust and 2 bad injectors. not too bad. tis was a week after putting in new gaskets on th eupper and lower injectors etc. so everything was clean inside.
Posts: 422 |
I put my ATX on the dyno again today... it put down 155.0hp and 146.9tq this time around.
The curves were nice too... over 150whp from 5800 to 7000 and over 140TQ from 3800-5400. In spite of having no secondaries, the car is putting down around 130TQ from as low as 1900RPM (where the test started).
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 1,537 |
Frank's Cougar did some nice numbers today at Crazy Horse.
I only pulled 121.4 WHP / 129.6 TQ. My HP peak was at 5750 RPM, and the Torque peaked at 2800 RPM, then leveled off at 115 TQ from 3500 RPM up to 5000 RPM. I was hoping for more, since the Tour feels like it is pulling higher. I'm thinking of doing the secondary extraction that Frank did, now that I have the Diablo chip installed. It should make it easy getting around the IMRC with the secondaries extracted.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
