so i'm going to sears point tomorrow for the drags but what should i set my konis on?
full soft on the front and firm on the rear?
and air pressure tips anyone? i'm thinking 38 rear and 32 front.
any other suggestions?
-jason
Full soft all around should be fine if your alignment is on the ball. It depends on load and what you're doing that weekend. . .if you're taking it to the track, full firm all around. I wouldn't set soft and firm between front and rear, I tried and the handling characteristics got twitchy.
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
O
O
Sears Point? man I wish I were you. Have fun for the rest of us that won't EVER have a chance to race there>
2000 Black SVT Contour
F
F
Full soft up front, and full stiff in the rear. You want to stop the rear end from squatting and let the front end rise up a little. Then again I dont have Konis so I dont now if this theory will work.
Definately go with full stiff at the back, maybe toy around with the front setting and see what nets the best 60' time. At least the front ones are easy to adjust wink laugh
Good luck.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
E
E
Perhaps Simon is right, but in my case, full firm all the way around works best for me...
Bill P.
There are 2 keys to success:
1.) Never tell everything you know
Moderated by  mbb41_dup1
