Posts: 486 |
I went to a dyno day with some FocalJet guys in New Jersey yesterday. Had a pretty good time, there were 2 Focus SVT's there that put down 149hp/134tq and 149hp/129tq, along with a Lightning that dynoed at 348hp/421tq. I haven't the slightest clue whether my results are good, bad, or average, but here they are: [img] http://www.angelfire.com/weird/covert1/dyno/jessman_dyno.txt[/img] Only performance mod on the car is a Borla exhaust.
Jesse Beltsville, MD 98.5 Silver Frost SVT
Posts: 2,848 |
hey you went to crazy horse!! Good guys over there. I went to a dyno day a few months back. The lightnings were laying down 350+ hp at the wheels! All you could hear was the whine of the eaton lol!
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 27 |
Click Here to view a video clip of JessMan's car on the dyno. Everything else I filmed can be seen in this directory.
Posts: 1,812 |
you put down as much as I did...but I even had headers at the time... your #'s are avg.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 1,375 |
How much does the SE put down? similar #'s to the SVT focus? If so i wonder how the MTX would fair against the SVT focus?
99 SVT Tropic Green #151 of 503/ 2760 total Born on 10/07/98 Adopted 7/15/00 LETS GO RANGERS (looking good this year)
Posts: 153 |
Originally posted by Slim Shady: How much does the SE put down? similar #'s to the SVT focus? If so i wonder how the MTX would fair against the SVT focus? Average numbers I've seen for stock Contour SE's are mid to high 140s hp, and high 140s to low 150s tq. So we have about equal hp, like 20 ft lbs more tq, 200 lbs more weight and 1 less gear. Edmunds says 7.46 seconds to 60 for the F-SVT, so I'd say stock for stock the F-SVT will probably take the MTX SE by a bit (drivers being equal).
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 539 |
I wish i knew....I live 10 mins from them.
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill| Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
